Hey all! Just after some advice on what the likely cause is. (R33)
My reverse lights don't come one when i'm reversing. The globe on the right-side is fine, but I haven't checked the other side. I assume they both run off a general fuse along with indicators and so on?
If they have their own fuse, then i'll have to start checking fuses.
If they share a common ground, i'll remove the carpet and check the other globe.
I guess I really don't want it to be the sensor in the gearbox... that would suck.
Other question!
Do the climate control buttons light up when the headlights are on? My window auto up/down lights up OK. The symbols on the buttons look like the translucent white that allows light through, so I recken it should
If it *should*, does anyone know if there are globes behind the buttons, how many and how easy it is to change?
Thanks!
https://www.sau.com.au/forums/topic/86868-reverse-and-climate-control-lights/
But my fingers are priceless! ;o)
Cool, thanks... there's a switch, but is it IN the gearbox, or on the outside? I can see a couple of wires plugged onto the side of the gearbox.
It's on the outside of the gearbox, it should have 2 wires going to it, you can just disconnect it and using a spaner you'll be able to get it out. Be carefull that oil may spil out, it shouldn't! The lights behind the climate control do turn on with your lights on. Don't know if you can change the bulbs as it's a complete unit, maybe if you really want to have lights there, pull it out and send it to a electrician! or once again for a cheap 5 finger discount you can get yourself another from the wreckers. Might be i little hard to hide though!!!!
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
