Hi
I have tein HR (non adjustable damper) and well whilst they are pretty harsh on bumps (i was prepared and can live with this), i have a quick question.
Would the stiffness of the suspension be harmful to the car? For example, many of Sydney's roads are broken, uneven etc and my car constantly goes up and down due to the hardness of the suspension. Is this very harmful to the car? eg. i dont want screws and bolts coming out of my car in the near future lol.
Cheers
Eric
https://www.sau.com.au/forums/topic/86875-coilovers-and-bumps/
In the long run yes...I had coilovers in my Silvia for a couple of years and there are stress fractures all over my bodykit and thats just an example. I also kept on blowing my headlight globes and it was only on my 4-5th replacement that I was told that because my coilovers were so hard, it kept on shattering the filaments in the globes. I've since replaced the coilovers with normal sports suspension. I enjoy driving it again :) Coilovers were never really designed for everyday on road driving. There is a price to pay I guess.
Yes a too hard damping or spring rate can be harmful, as well as making the car lose grip and be slower on the track.
But FFS a coilover is when the coil is over the shock. Anyone wanna guess just how many cars other than Skylines come with this standard??? So what do you all use if you don't have coilovers?
:rant by terminology NAZI ends:
Just to add further 'helpful' comment, Japanese suspension is usually rediculously hard and oversprung. You can get new springs or better yet, the Whiteline stuff which uses Bilstiens.
Cheers
Im converting to a live rear axle with leaf springs B)
When you order your coilovers you should be given an option as to the weight of the spring. I have some D2s comming for my Silvia which are a couple of kg lighter than standard so that they can account for Townsville roads... and I don't intend to ude it on the track :D
Cheers
stu
they can supply softer springs?
might give them a buzz
thanks
sorry for being lazy and not searching but whilst on topic wat rates are good for a r34?
You may not be able to simply change the spring rates, the damping rate in the shocks are valved to suite the springs rates that it currently has. If you change the spring rates you might have to change the dampening rate as well. Compare the total cost with the Group Buy on Whiteline and Bilstein.
http://www.skylinesaustralia.com/forums/in...showtopic=88141
:rolleyes: cheers :rolleyes:
    • Big single, and seqy. #sorted
    • The R32 suffers from an instrument binnacle that is uncomfortably close to the design of a VN Commodore's. But beyond that, the layout of the rest of everything, and the materials (ie the vinyl coverings on dash, armrest, etc) are acceptable, and the patterns on the fabrics are not as blergh as those in the R33. And R33 seats are....quite unattractive. I know it's only small details there, but I reckon the R33 got worse than the 32. But the big blergh is the overall shape of the dash on the R33. It's just has that whole Maxima/Pulsar sort of look to it. Nothing special at all. Generic Nissan sedan. Whereas, at least the R32 dash/binnacle was different. Less a wide expanse of boringly curved plastic. More a "cockpit" sort of look, even if nowhere near to the degree that the A90 Supras got. R34 seats look good on their own, until you realise that they are indistinguishable from the shape and fabric on 70 other Japanese cars. And the foam bolsters on them suffer even worse than the earlier cars. Other than that I don't really have an opinion the rest of the R34 interior. I took the bits of the R34 I wanted (brakes and engine) and added them to the best external appearance Skyline in the modern era (the 32). So nyerr!
    • Can I be your first customer? I would like hard lines done for the fuel system, 8AN up and 8AN back and the underside wire wheeled and coated (brush or sprayed) with that black tar shit.
    • Speak for yourself, I love the R33 interior. 32 is blergh. I like the 34 interior too. Then you start getting much newer in most cars and they all turn back to blergh. 😛
    • 500-600hp into a RB is already 'sinking endless amounts of money' into an engine. Especially a 30 year old engine. Unfortunately this is the RB Game. Considering stock power (or at least stock components) will do ~360whp on 98 by simply turning up the boost on the stock gear on a RB26, that would be where I'd say the cutoff point for "sinking endless amounts of money into the engine" Cause to even do this reliably you'd probably need to replace all the bits anyway cause they're old, starting your sinking journey anyway. I reckon the least painful way is rebuilding the engine to make 50hp over stock lol. The 'plan your ownership around a rebuild' was a common saying 15 years ago.
