yes and no.. depending on the coat used..
Some latter Nissans (R33 1.5 onwards) use a different clear coat, that can quite easily be stuffed with standard cutting compounds. If your paint is a bit dodgy, then it can only get better via a c&p.. did wonders for my R32 and cars with older cars i have used. With an old car that is exposed to sun, you have to expect the paint to be on its last legs (15 years or so).. so something u always have to factor in anyhow if u want bling bling
Apparently what is meant to be great is Mothers Clay, and not quite a cutting compound, it fills the small scratches.
Might be similar to what RellikZeppher is saying.
If you're refering to Mothers Clay bar then it isn't for filling in scratches or polishing at all. It's for removing particles and buildup from the paint using a lubricated clay bar directly against the paint.
Works great for cleaning up paint but will have no effect on scratches sorry.
ive been looking for the mothers clay bar for a while, i cant find anyone who stocks it!!??!!??
hmm duno why everyone is so scared to cut and polish... i borrowed a mates rotary polisher and cut my car using that and Maguiers fine cut ... and then hand polished and buffed... worked a treat, made the paint look and feel brand new!
only thing to be carefull with when using the rotary polisher are the seals.. other then that i dont know how you can go wrong
-Ruffels
so what does that do?
as far as i know c&p simply removes the harshness of scratches by either removing the edges of the scratch (i.e. the rough debris surrounding it), or removing the topmost layer of paint, assuming the scratch is not deep enough to go through to the undercoat or metal. It obviously does not "paint over" or cover any scratches.
If you need rto ask this question, pay the money nd get it professionally done. Once its restored you can work on keeping it in top condition.
Dont buff it with a powered buff unless you know what you are dooing, you can compleely remove the clear coat if you are not careful, edges are especially vulnerable, and swirl marks will probably be left behind.
A clay bar removes from the top of the paint without affecting the clear coat at all. A cut and polish uses abrasive material to actually cut into the clear coat itself. You get a shiny finish after a cut polish because you removed the top most layer (10's of microns maybe) of clear coat leaving you with nice shiny new paint which was underneath.
This has the side effect of removing very fine scratches that were in the clear coat and softening the look of more severe scratches.
Done poorly or too many times it will wreck the paint.
Clay bar's are stocked at Autobarn. Mother's aren't the only brand and all the brands are the same so buy any clay bar.
Use a light cutting compound with the rotary tool. Do not try doing the bumpers or the side mirrors. Use a heavier compound on the bumpers but use a hand polisher.
For the buff marks use a hand glaze, that will remove the marks.
http://products3.3m.com/catalog/us/en001/a...heme_us_aad_3_0
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
