I was in supercheap the other day and saw this rampage audio cables and connectors. I saw they had 8 gauge ring connectors, asked the chick at the counter if they did and bigger as I needed 2 gauge, but they only did the 8.
Has anyone else seen/haerd of Rampage?,
if so do they do 2 gauge ring connectors?, as I needs some ASAP for my stereo
if theres any other brand (stinger, aerpro) that do quality ring connectors (these rampage ones looked really well made) let me know
cheers
Tom
Rampage, as far as I am aware is supercheap's "cheap" audio gear, im not surprised the don't make any other sized connectors. Aerpro or Stinger would both make these size connectors, or yeah Jaycar has everything you need anyway.
Nath
WTF 2 gauge!!!!!!!
what amp have u got?? over 1000W?
no, but I have run 2 gauge cable so I need 2 or 0 gauge connectors
I have 2 Alpines. MRVF340 and an MRDM500
So Rampage is cheap shit!, I will steer clear then....I have been into Alberts, Audiocom, Car Stereo City, Strathfield, Supercheap and West Cost HiFi an NONE of them had anything other than 8 gauge.....WFT is up with that.....all these car stereo places have no calbing or accessories that I need, its been the same with the 2 gauge cable and a few other thing, taken me ages to get all this stuff ;)
for those amps you wont need anymore than 4 gauge wire, thats stil pretty thick as it is. try Jb-hi fi, u can buy 4 gauge for like 6bux p/m from my memory, man 2 gauge wire is like 2cm in diameter. u arent running power lines through ur car LOL
I've already run the cables tho :P, just need to mount the amps and connect it all up...
Aerpro, Rampage, USAudio, Audioline (& Jaycar's range)... Take them out of the packaging and they're identical.
They're all manufactured on the same production line, most of them are distributed by the same importer.
In the Rampage brand, you'll find 4GA rings (RMP45) - most stores wont stock them as they're not pushed by head office. And they didn't want to get 2GA - too expensive for such a cheap range. 2GA Ring Terminals are cast brass - makes for a few more $$$. You'll only find those under Aerpro (or Jaycar, or Stinger, or Stinger's new brand, but I don't think we're getting that here...)
And yeah, the subs look ghey... Strangely, they were independantly designed by mechanical engineers but fall into the same category as the rest.
Just reading an article bout Rampage audio stuff, apparently some uni students (possibly melbourne uni) designed all this stuff on broken down mainstreamers (sony, pioneer, kenwood etc) and just took the best idea's and changed some of the parts, i know a few people now with rampage gear, and some of it's actually quite good. If i had my time again and could save my self quite a bit of money, i would put this stuff in my car with out a doubt.
Just reading an article bout Rampage audio stuff, apparently some uni students (possibly melbourne uni) designed all this stuff....
Swinburne Design, actually. But yeah, that's the basis of it.
ive never heard rampage hooked up, but from what ive seen (supercheap, 2 12's in a ported box) they looked pretty cheap..
the rubber around the cone didnt look to good, but that could be due to it being a floor unit and a bunch of f**kwits trying to test the recoil with there palms :(
so i have judged this book by its cover, but apparently i have made the wrong judgement..
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
