Has anyone got a use for one of these in 3.9 ratio? AND is $250 to much money.
Comes complete with half shafts if I don't buy them first.
Cheers.
i was under the impression that all R200's were LSd's apart from some of the 280xed ones which dont fit r30's
Do the axles fit like this, or are they like the old 1600 styles with the 5 bolts holding the axles seals in place? also do you know if i can fit the old style axles into this type of diff?....bugger it ill give it a go anyway..BTW my R200 simple spinner only cost me 100 bucks(no axles tho)it came from an r31
most R200 are not LSD :)  only the later skyline ones 32 onwards are all LSD and they are short nose not long nose
Beg to differ...All the DR30 range, and i beleive the HR30 and Paul Newman versions all ran a clutch pack LSD as standard from the factory...You the part about the long nose/short nose bit right though
Beg to differ...
Depends on what you define as 'most'....long nose R200 was used all the way back to 260Z in 1974, but LSD wasn't a factory option for cars sold in Oz and 'our' R30's only came with an R180. So 'most' turbo R30's sold in Japan may have had an R200 LSD, but long-nose R200's with LSD are rare in Oz and virtually all are imported or retro-fitted aftermarket jobbies.
Yeah, the thing is, "most" of the (long nose) R200 diffs that are in Australia now came out of Zeds. Of all the Zeds, only the Z31 300ZX Turbo came with an LSD from the factory.
On top of all that, you have the 10mm / 12mm crownwheel bolt hole issue...
Do the axles fit like this, or are they like the old 1600 styles with the 5 bolts holding the axles seals in place? also do you know if i can fit the old style axles into this type of diff?....bugger it ill give it a go anyway..BTW my R200 simple spinner only cost me 100 bucks(no axles tho)it came from an Hr31
Fixed :)
It isn't an issue drilling out the centre's holes, but it can be more of an issue going back the other way (ie. sleeving the 12 mm centre holes for your 10mm crownwheel - like Stagefumer11 might need to do).
The crownwheel may not locate on the bolts, but they help the crownwheel maintain friction on the centre. When the diff gets abused, they sure can be in the line for some punishment! I have seen these bolts sheared off more than once...
True but open R200's are still around and the 12mm bolt type is the best option here , why Nissan went that way with Turbo DR30's , R31's etc . Once you have the LSD carrier the rest is pretty strait forward . You need to find a mechanic thats been down this road many times and knows what what .
For everyone's enjoyment, I thought I would show some photos I just took in my shed. I happen to have a 10mm and 12mm (longnose) R200 handy...
A shot of the subject at hand. 12mm bolts on the left, 10mm on the right:
Note the difference in crownwheel thickness:
Another shot of the crownwheel difference:
Edited by Matty T
Matty I'm curious to know the ratios of both of those as most differential manufacturers have a different offset somewhere in the middle of the ratio spread . I can't remember with R200's but I think it may have been around the 4.375 point . Anyway is not generally a drama as theres heaps of latitude for correction , my old H190 with the Detroit locker used an approx 100 thou (2.5mm) spacer plate as its offset was intended for the 4.625 ratio which was the change over point in H190's . R200's are much better than H190's because the spacer rings or shims are on the outside of the carrier bearing races not the inside (pulling bearings off to select fit shims is a time consuming pain in the butt) . So the spacer rings can be used to a limited degree for changing offset (as well as setting bearing pre load) . The really difficult situation is where the carrier with the lower range offset is used with the higher range offset crown and pinion as there is no way to move the crown wheel far enough to get it in next to the pinion .
I don't know if this makes any sense to you but understand that every different ratio will have a slightly different crown wheel thickness . This is because the number of pinion teeth change and so must its diametre . There's no whay Nissan would have a different main housing for each ratio so the crown wheel thickness was varied to allow the difference . R200 ratio's ranged from around 3.1 to 5.3 , the tallest having the lowest no of c/w teeth and highest of pinion teeth and the shortest vice versa . The carrier flange offset changed in the midst so that taller ratio c/w's would not be too thin .
Cheers A .
And so would Stu Wilkins amongst others . Anything shorter than 4.375 is now rocking horse`do do . Stu searched world wide for 5.1 and 5.3 with no luck . I remember seeing one of the last brand new 5.1's before it went int a Zed rally car . I think these two ratios were Nizmo options not used in any production vehicle .
Cheers A . P.S if that 3.7 had 12mm bolts I'd buy it off you !
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
    • If it does get a turbo it would blow the JCW Mini out of the water considering how "close" some of the tests were. Then again the Mini would probably get one of them Stage 69 tunes.
    • Next up, the extinguisher is mounted but really only temporary because I ran into clearance problems (the bracket fit fine....until I put an extinguisher on it). It picks up the seat bolt mounts but has long bolts running through 20mm spacers for now Doing it properly requires a bit of quick welding but I ran out of time, this will do for the practice day
    • Family events weekend but a snuck a couple of things in. NSW state champs were down at Wakefield so I got Gordon Leven's to bring some A052s down in the right size for some spare rims I had that "fit" (actually ex-Leaf Nismo.Rays in 18x7.5). Tyres are 235/45/18 so they are narrower than stock (19x8.5s) but I need to keep road tyres on it for daily use for now. In a first, those weird size tyres had been in the yoko warehouse for so long (4.5 years apparently) that they offered 4 for the price of 2....so 4 practice tyres for about $1100. Bit of a bargain for sticker tyres, considering the real purpose of the practice day is mostly to see how the various temps go (and the weather is due to help, forecast 32o). In terms of race wheels, it looks like I should be able to fit 9.5 fronts and 10.5 rears but 18 vs 19 height will be based on what tyres I can get in the right size - good tyres are very limited in available widths in diameters above 17" so some planning is needed. Once I'm sure this car will work I'll order a set of custom BC wheels like I did for the R32, you can get exactly the right width and offset to make the most of the available space in the wheel well (the 32 has 295s all round on 18x10s and they are awesome) Incidentally A052 are asymmetrical but not directional which is good news for rally use if the front and rear wheel sizes are different because I can swap them side to side on the same axle. Directional tyres are a nightmare with staggered size wheels because each tyre is fixed on that corner unless you can get it rotated on the rim (not really practical mid rally in most cases)
