Hey guys,
I pulled my system apart yesterday, sound insulated the boot, cleaned up some wiring and now when i turn it on, there is no volume until the very end of the volume range (like i can't hear it until its right up) and its VERY distorted... and 1 channel on my amp wont work...
Its all pioneer stuff, 4 ch amp all 6" speakers, nothing giant, no subs atm... everything has been put bacjk the same way (if not better)...
any ideas?
Christian
https://www.sau.com.au/forums/topic/870-distorting-speakers/
Double check your wiring.
Then check all the settings on your head unit.
If its all ok then triple check your wiring.
Check everything, power, ground(make sure it is a nice and clean connection straight onto the chassis).
Check your RCA's are in the right spots eg(front - front, rear - rear)
Check the phase of your speakers, positive to positive and negative to negative.
If this doesn't work, then take it to a professional installer who'll probably find the problem inside a minute.
Hope this helps dude.
https://www.sau.com.au/forums/topic/870-distorting-speakers/#findComment-18762
thanks man.
the only thing i can think of (which would take me ages to check )is my speakers being negative - positive.. but i wasn't sure if that would cause the problem i am experiencing...
What do you think?
https://www.sau.com.au/forums/topic/870-distorting-speakers/#findComment-18764
It maybe a dead RCA lead if your running off an amp.
But I would do what MUD specified first as there are
more chances of something going wrong there than
the RCA breaking. Did you have to pull hard at any
time to get the RCA through? Try changing the rcas
around to test each side.
Did any wires go through any holes which have the
chassis exposed which can cause it to cut through
the cable?
Could be any of these.
Try looking at these as much as you can before taking
it to an installer (dead money). Might be something you
just overlooked.
https://www.sau.com.au/forums/topic/870-distorting-speakers/#findComment-19238
seriously, i dont think so...
i think i may have just screwed a bit of the wiring somehow...
but i'd like to test it in somebodys car, if it does work then i WILL sell it for like $150 (retails for about $250 i think..)
Christian
https://www.sau.com.au/forums/topic/870-distorting-speakers/#findComment-20594
uh huh, nice constructive addition to the thread, Ryan.
A new problem has arisen, its not a new problem actually, its an ongoing problem but i thought i resolved it before.
I think this is hardware related (maybe my HU or Amp) - every now and then the speakers cut out, but you can still JUST hear music out of them, and they cut in and out... its hard to explain, once it starts doing it, it will do it for a while, but then it could go a few days without doing it again...
crazy ass car!
https://www.sau.com.au/forums/topic/870-distorting-speakers/#findComment-20745
haha, sorry dude i let my hatred for sony car audio be known everywhere i go i cant help it.
hmm, maybe its either
a) faulty h/u
B) bad wiring (but u just re-wired!)
c) the cars electrics are shonky, need to be re-wired
GTR-80Y has a problem where his speakers only work on one side sometimes, and then sometimes one side cuts out u can hardly hear the music, and then when u stomps on the brakes the stereo turns off altogether and you need to turn the car off and on again for it to work again
R33 GTSt's have shonky wiring me thinks.
https://www.sau.com.au/forums/topic/870-distorting-speakers/#findComment-20755
now without the EQ it is:
  • Pioneer H/U (can't remember the model number but it was like $450 a few years back)
  • Pioneer bullet splits at the front (currently only the midranges are hooked up cause i am trying to find somewhere to mount the tweeters)
  • Crappy Panasonic 2 way 6" in the rear... waiting to make a custom parcel shelf for my 6x9's
  • 4x150 Pioneer amp
no subs atm.. the stereo is pretty basic atm, its not a priority in my car.
thats why i am so confused, its not like there is much to break.
https://www.sau.com.au/forums/topic/870-distorting-speakers/#findComment-20758
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
    • Remember reading about this not too long ago. been for sale for a long time  this is like when the wife says you need to sell the car so you put it up for a ridiculous price no one will pay
    • You are perhaps suggesting that it is not a super car? Well....it's not an AU.
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingie  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like
