Guest AFRO_BOY
Currently it sounds like shonky wiring, as if u've got some non-insulated wire somewhere and its earthing out. Its 2 am and the boys have just gone home coz we've been up all night installing half my system (stupid fool set my fronts to right - front left... left - rear right). Anyways back to the point, i suggest you check any cables especcially any brass/gold plated fittings like joiners incase u forgot to insulate them.
I just recently baught an alarm which caused very very similar problems in my car but it affected the central locking and interior lights. I assumed it was bad wiring but as it turned out, it was a faulty alarm unit.
If your sure your wiring is set, test your amp in someone elses car simply coz its easy to move. if that comes up alright then your final option is to take your HU to a specialist.
BTW, i assume you've faded and balance to check each speaker for faults, you may have blown something (doubt you blew ur splits but those panasonics sound dodgy with such a big amp).
:burnout:
hey prank ill have a look at your system if you want
this is what i do for a living
im an electronics tecnician if you were wondering
theres heaps of things that can go wrong sometimes its the stupidest little thing
just let me know when your free and ill se if we can sort it out
Originally posted by MYGTST
yeah jimbo i can do theat
and i work about 1 min from your place
IBS electronics
93a liverpool rd summer hill
prank gimme a call and we can arrange something
0414 837 902
MARTIN
Cool, will do - thanks again man!
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
