Items:
# Intake manifold $80
# Ignitor $150
# Later model rb20det turbo (slightly bigger from a series 2) $300 or make a reasonable offer
# Coil packs x 12 $25 each
# Standard Injectors x 12 (red) $100 for 6 (SOLD6)
# Standard exhaust manifold (no cracks) $ 100
# Standard Turbo ECU + harness (suit GTS4) $150 SOLD
# Crank angle sencor x 2 $150
# Standard Complete head cylinder including all valves, cams ect (no cracks and looks very clean as it was recon'd recently) $200
# Alternator $100?
# RB AFM $150
Item Condition: Good, all parts were working when taken off the motor
Reason for Selling: No need for parts
Price and Payment Conditions: Prices ive add is what i think they are worth or seen them go for, if you think they are overpriced, nominate a price.
Contact Details: PM me or call me on 0404 421 615
Thanks
Edited by 510RB
https://www.sau.com.au/forums/topic/87004-rb20det-parts/
