BLKSKY Posted September 8, 2005 Share Posted September 8, 2005 does anyone know if you need to replace the standard RB25DET AFM with a Z32 so that the power fc will work? thanks all and what power increase i will get with the power fc, 040 and fuel reg i have 170rwkw with - pod filter - 10psi - dump and front - HKS hi-power Link to comment https://www.sau.com.au/forums/topic/87023-power-fc-with-z32-afm/ Share on other sites More sharing options...
paulr33 Posted September 8, 2005 Share Posted September 8, 2005 you dont need z32 to make powerfc work, supports stock afm fine. without a fmic id say probably 180rwkw ish. Link to comment https://www.sau.com.au/forums/topic/87023-power-fc-with-z32-afm/#findComment-1572111 Share on other sites More sharing options...
BLKSKY Posted September 22, 2005 Author Share Posted September 22, 2005 you dont need z32 to make powerfc work, supports stock afm fine.without a fmic id say probably 180rwkw ish. <{POST_SNAPBACK}> cheers man, sorry for late reply! Link to comment https://www.sau.com.au/forums/topic/87023-power-fc-with-z32-afm/#findComment-1599780 Share on other sites More sharing options...
