450hp R33 Turbo Swap 4 Sale Brand New From Usa
Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life. -
Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank. -
