Well ppls You don't want to buy a Genuine Nissan R32 GTS-T Radiator.
Sit down... $935.. OUCH.
Anyhow NATRAD Radiators can replace top tanks etc.
I discovered that my top radiator hose was a little loose.
I soon realised that the plastic where the hose slides over had collapsed.
Natrad radiators quoted:
$145 for the Radiator & Motor flush/Rod/pressure test & Thermostat inspection Test.
$95 for the Top tank that is aftermarket, the aftermarket is apparently better due to the plastic quality and thickness.
Autobarn also can get the Radiator hoses for these From GAtes.
Top hose is $19 and the Bottom hose is $30.
Thermostat. I bought one from Motor mates as the ones from the VL are the same. BUT.. it is a dodgy one as it doesn't close properly and the car in cooler weather doesn't heat up.
So I'm going to buy a Nissan One for $48. The VL one was $24.
Total Price is going to be $335.
AND.. my bleeder nipple has crossthreaded its self due to undoing it when the metal is really hot (soft).
And ppls don't use anything like gasket goo on the bleed nipple to stop any possible air leaks when troubleshooting.
That is probably what made it cross thread.
https://www.sau.com.au/forums/topic/8707-bran-new-radiator/
Joel i got a brand new radiator for my car as the top tank was stuffed, it cost me $320 inc GST, from the mob down the road who looked after me. It is the same as stock just has more cooling fins.
PWR ones are about $650 trade price for a 38mm core full alloy radiator.
https://www.sau.com.au/forums/topic/8707-bran-new-radiator/#findComment-127861
  • 1 month later...
Silver... how much did the PWR radiator cost you all together? Is it possible for a raditor to brak due to big impacts... I went over a big median strip yesterday... just need to know cose of dealer warranty see if its not my fault...
https://www.sau.com.au/forums/topic/8707-bran-new-radiator/#findComment-216827
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
