I know this is not related to this topic. I wanted to let you know that I am a fully qualified and Licensed Motor Mechanic and I am available to work on Skylines, Silvia, 180SX or any other make of car for that matter on the weekends and evenings etc. I am employed full time by a reputable tuning shop. Experienced with RB20DET, RB25DET, RB26DETT and SR20.
Can supply and fit all aftermarket parts, electronic boost controllers, aftermarket fuel pumps, high flow fuel injectors, aftermarket fuel pressure regulators, turbo's, camshafts, adjustable cam gears etc etc the list goes on. Can also remove and replace turbos on Skyline GTR RB26DETT.
Also general servicing, spark plugs, timing belts etc.
If you use my services, it means you will get the exact same quality of work you would expect from a reputable workshop but at about half the hourly rate! This is a substantial saving.
If you are interested or you know someone who might be interested email me at:
[email protected]
Cheers...
Those look f**king awesome! How much would they be you reckon? How many mm wider are they?
they are currently $650 in NZ, obviously + postage etc will all add up. but the ones made here should be cheaper, plus u wont have the same issues with postage. im mainly interested in bringing one set in so i can duplicate it cheaply as i'll need a few sets a year.
Just got some new shoes for the 4 door. Didn't want to spend a fortune and these popped up at a decent price. Its not that tough yet but slowly getting better.
Weds
17x8 +6 215/45
17x9 +13 215/45
Could do with a 6mm spacer all around and some serious low (the height really lets it down). Unfortunately can't go uber low as the roads to work everyday are quite hagard and getting it on/off the trailer every track day is all ready a hassle.
  • 3 weeks later...
    • Welcome Gabriel, and thanks for saving one of the less famous cousins!
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
