konnect/jaiks old monster? , 4.9/5 because of the nasty dent
yeah ryans old sled...i made it presentable again
shhh what dent?? :D
yeah some old lady in a 2010 lexus backed into it. :( insurance came through, but then i spend the money on new coilovers, diff, blah blah....
priorities!!
shhh what dent?? :)
yeah some old lady in a 2010 lexus backed into it. :P insurance came through, but then i spend the money on new coilovers, diff, blah blah....
priorities!!
haha back to 5/5 then :P
looks good Karl, your car has my standard turbo on it haha, sold it to Ryan just before you bought it
Cheers Kris, not quite as boss as your ride just yet but I'm workin on it :P
bahaha dude I ripped that thing out a while ago. it's holding a tarp down in the backyard :)
haha that turbo was good, whats specs on the wheels?
u need an autech front bar to complete the whole kit man, i got a spare muahahahaha
man my kit game is all f**ked up atm...
i felt bad for stockers so i swapped him the standard bar and addon for some whacked out bar. im not even too sure what it is. its like an autech but with an flare. doesnt look bad...but it doesnt fit quite right. so basically i need a autech rear AND front :)
hook a brother up!
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
    • I should video mine, will prob do it tomorrow    Between 1st and 3rd, you could fit another two gears. That is how loose and wobbly it is   horrible:(
