Just 2 shots of mine here @ work
Car needs to be lowered iam still deciding what way to go if it should be on coilovers or s13 chocks with lowering springs
It has C33 rear disc brakes and bigger rotors and discs up at front ,inside are two recaro front seats Momo racing wheel
And a non turbo RB25 VVT
Ghost Ryder are they work schwert sc1 on your car??? Odd choice for a cefiro I'll give you that much :P
And yes kris's SSR sp1 have 4 stud.
I don't know how he's gone this long without getting bashed for them!! :P
Mines is a work replica lol
But i would like to get a set like kris's
Ok qld time, few of my mte cef's
Mine: i built it from ground up. not alot of cef left in it, ill do a build thread soon. My 4th cef but no way near as extremeas my first one.. wish i never sold it!!
Davo's: gets used for its intended purpose, hits the hills, the track, the street and has all the good quality gear.
Vance's: Got used and abused. but i think is now being sold as a roller.
Micheals track cef: skidded trashed and taken home!
Lee's cef: daily atm, soon to be skidded!
Justins cef- pretty well setup. Hasnt been skidded in ages
Micheals cef: come along way and alot of change - love it
Tomfio' rig:just got back on the road after he got confused and tried to go jz... back to rb now D
there are a few more. ill post them up later!
Only one has a sunroof! . more pics A-stat , some nice cars in that bunch , are you planning on re-spaying yous?
someone should swap me their ceff with a sunroof for my one without :ph34r:
My ceffy may be up for sale soon. Need a new daily ASAP!
Sunroof, RB25, manual, two way.
plus cash your way??? :P
yeah why not :P
yeah the bay has been sprayed already. But im thinking 350z blue
ah yep , nice :) you better put a thread up in the members section :P
you should swap me for mine , then sell mine so you can buy a daily spec :ph34r:
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
