Your car looks tops all painted up mate, much better with the white bonnet. I reckon a set of low offset meshies and you'll be done.
Jap import spares have some awesome new wheels in stock, a new container just landed.
Yeah matsuri was awesome, shame it rained almost all day but i still had fun. first time in over 3 years so it took a while getting used to it again!!!
Thanks, yeah I've been looking through their meshies for sale lately, I think my favourites are the VS-XX and Stitches so far, but open to suggestions. Still have the S2 grille to put on, which I reckon would look good with silver meshies. I should really take one of my P1s off to check the size and offset...
Edited by Stang
I don't really get the whole meshies on cefiro thing.
Personally I think you should follow similar path to me, and get rims similar color to the body of the car.
Something 5 spoke.
Looks heaps tougher IMO.
http://www.skylinesa...-1307340538.jpg
Maybe some white TE37s or Drifteks.
Anyway on that note: Looks f**king awesome all painted up.
Why did they paint over the cornering lights on the front bar ??
Edited by Nic_A31
the p1s look ok on your car (ok i personally hate p1s , but it's not my car) , i wouldn't stress too much , if your set on meshies though , go for a set with flat dish like the vs-xx (i.e the band is flat , not stepped like the other rims pictured) , make sure they're clean like the car (maybe even paint the center white for something different?, only if they aren't chrome , i have a lil thing for chome ) , and as much dish as it will handle (and maybe 18" if you can find them) front and rear and then , stance , stance makes a ceff as much as wheels do , look at kris's last pic ^^ for a reference :)
Something 5 spoke.
Thanks, yeah pretty happy with it looking a lot cleaner compared to when I first bought it. Not perfect, but it's an old car.
I do like 5 spokes, and had pondered Meisters as well...but I don't exactly have a lot of money to throw around. Not sure Drifteks would suit it. Not like it's a big rush to get everything at once anyways, tempting as it is.
Wasn't using the cornering lights and thought it would look less busy if they were painted the same as the rest of the bar.
please dont put drifteks on it
:laugh: Don't worry, I won't. ;)
I quite like the P1s really. Since I've only just recently recovered enough to start driving the Ceffy again and doing some mods, I've been getting a bit excited thinking about various options for appearance and power. I do like meshies on quite a few Jap cars I see. Stepped rims can look good, or a bit odd, depending on the car of course.
At the moment it's about as low as I would want to go without beaching it on anything higher than a $2 coin, have already scraped on small speed bumps a couple of times. Kris' Cef does have an awesome stance, but cops here would probably shoot you in the face for that combo of rims and ride height. :laugh:
I'll keep looking around at pics of various wheels and stuff anyway. But may go for some more fasts rather than expensive rims. Making 139rwkw on standard boost and tune at the moment with FMIC and exhaust.
Edited by Stang
^^ THIS MEANS WAR FOOL! :spank:
actually i think SA police would be much nicer then VICpol :glare:
looks like she's in good hands by the way its progressed. did you end up getting some lean air flow ratio's during dyno run if so care to state xx:xx ratio?
I'm not sure, I was really worn out after being at the workshop for a while taking photos, so didn't ask too many questions. I mainly just wanted to make sure it was running ok after only being started once between June 2010 and May 2011.
Here's the readout from the dyno run, I'm not smart enough to know exactly what all the details mean...
Something 5 spoke.
I do like TE37's or even low offset CR Kai's on Ceffy's but drift teks.... :yucky:
Im over seeing Ceffy's with urgays kits and drift teks.
Personally, meshies with dish & slammed.
i like the P1's on your car aswel they suit it, have a look at Works510's car aswel with p1's looks decent
if you want more stance pump the guards and put big f**k off tires on em to scare kids and shit
Edited by Kris..
It's been a while since you posted in here , any updates on the c33??
Couple more from Matsuri. Again, quality of the pics are sub-standard!
Just one I took on the weekend
Your car looks good mate , was that the rb25 one with the laurel dash?
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
