i dont know why it was done. Some say it works better and i also read it has something to do with the last cylinder .
But his car works well has a couple other mods run well
Check out our group on facebook
https://www.facebook.com/profile.php?id=519324105&sk=photos#!/groups/210592938965823/
yes but the rb26 front facing intake mani works well.
and the sr20 comes from factory facing that way.
so there's a way to make them work and also your ment to get a remap after installing one as AFR aint right
Edited by Dan_J
got proof/dyno sheets to sheets to show an rb26 plenum on a 20 or 25 makes a difference?
and an sr20 and rb26 were designed by nissan to work with a forward facing intake manifold thats why they work on those motors, rb20/25 were designed to run with a side facing plenum coz it obviously works
your right so therefore a front facing plenum can be designed from scratch with ecu tuning to run right. not saying everyone should get a hectik front facing intake.
just saying
Edited by Dan_J
Aaaages ago i sold it , i swapped it for a s14 s2 , then swapped that for a r34 which is my daily . poor old girl has popped 2 gearboxes by 2 different owners since i sold it , the vskf's are too heavy for skids with a 20 box :P , it (the laurel) is in the members ride section somewhere
    • Last year I got a set of MCA street coilovers for my turbo Forester after my son hitting a concrete gutter/wall on a small bridge causing the whole drivers side suspension to get bent because the rain just made the car slide out I love them, I think they were $2400. even had a hiccup of have the wrong hub configuration (my fault) so got onto MCA and they sent the correct shock ends overnight parts from QLD, for free!  I was very impressed with their customer service and quality of the product
    • They've had some weird failures on their brake actuators. One of them was because they added some kind of lubricant to the factory fill brake fluid that aftermarket brake fluid didn't have so it would affect the seals. Another was just mysterious, probably internal corrosion or something eating away at Prius brake actuators. Parts alone for those are a few thousand USD so not a cheap fix.
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
