yes been very busy getting ready for Super Drift
oil cooler and relocator kit
radiator flushed and new top
new gauges
rb24 motor new tomei rings/ 1.2mm gasket / new bearings / 82mm tomei forged pistons
17x8,9 drif teks, running 235/45/17 wanli rear
new uras kit / paint
sparco seat
rear camber arms
rear strut bar
ummm thats off the top of my head anyway :S
fark man im so jealous. I cant even afford a f**king diff :(
What oil cooler did you get ? JustJap ?
running a hks 2530 on it still but got issue's somewhere power seems 'restricted' to around 180-190rwkw !!! :dry: the torque is noticeable but have to sort this out now that i have time :thumbsup:
the 2530 has made 236rwkw on a stock rb20 motor so would've though similar peak power with added low/midrange... hmmm
Heres some pictures of my laufiro as she sits at the moment. I bought the car for 1k in rough as guts condition so i wouldnt have to drive my done up s14 k's to work every day. After a few burnouts and a very cheap rb30, a few blown diffs etc i decided this was my next project.
The pictures shown are when the car still had the rb30e installed with nissan rocker cover, rb20e inlet, injectors and computer. It came out later that day.
Car is sitting in a shed waiting for the engine to be built. (NZ)
Specs when completed (should be about 6/8 months)
rb30det
r32 rb25de head
rb25det (r33 trans) - have rb20det at present but will be upgrading
gt3540r 0.86
tial external wastegate
ecr33 power fc modified to suit
q45 afm
sard 700cc gtr injectors with resistor pack
acl pistons
acl race bearings
gtr head gasket
performance springs valve springs
block decked to give perfect 8.5.1 compression
I have most of the parts together here now, just waiting for my mechanic mate to get the motivation to start the engine build.
17x8.5 30 offset rear Racing Sparco rims
17.8 35 offset front
The body is an 89 cefiro that was as rough as guts when i got it. The laurel front was off a friends parts car and the whole car has been sprayed in my garage. The engine was installed as a friends boss had a cheap one and the rb20e wasnt doing its job spinning tyres.
I pick up some custom laufiro guards in a week or so time so that should complete the exterior. I dont plan on fancy kits etc as they are likely to get damaged and ruin the drivability of the car.
It should be good for 320+ kws when completed
Edited by SirRacer
  • Like 1
sir racer were can i get some of those lofiro gards can you please post a pick of those because im looking at doing a lofiro convertion aswell
they were custom made by someone in auckland nz by combining both cefiro and laurel guards together. apparently its a shit of a job so will cost around 600+ easily
i have thought about getting a fibreglass copy made but dont really want to fork out 400 to get them copied then loose my individuality. im in NZ anyway so that prohibits you getting a copy of mine
Thanks yeah I love it more than anything :dry: All work carried out in Japan.. Fronts are aftermarket flares that have been smoothed over. I'm guessing the rears are the same with the added complication of the door.. but yes large quantities of bog is involved :)
Edited by Drift_Limo
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
