Is that your 33?
sure is, had it a few months now
Ceffy getting some attention kriss? What size/offset do you run on the 33?
yeh done GReddy plenum, Q45 TB, Tomei rail, bigger injectors again, just needs cooler piping and tune now
wheels on the 33 are 17x9 +17 all round with 225/45's, will get some better pics once new front bar is on it
Do you have adjustable arms and shit? Mate has a 33 four door but he's retarded with wheels so I'm sorting that bit. Only thing he wants is cst's but he's nuts about scrubbing and stuff. Trying to work out wether to get 9 +15's all round or play it safe to avoid his whining and get the +30's. Be 215/45's on the front but no adjustable arms.
Good to see the Ceffy getting some attention! I'm too broke to do anything on my laurel.
+15's will be poking and definitely scrub. Depending how low it is too, without guard work the tyres will be touching the rear guards. If dudes paranoid about rubbing would be better off sticking witth +30's they will still look decent enough,
Looks tough, need more pics!
thanks man, fresh painted type M bar goes on tnight so will take some pics this weekend
nah all standard arms man, 9 +15's will be fine, mine doesnt rub at all anywhere and the rear even has room to go to a 235/45 which i will be doing, just go 215/45 fronts and he'll be sweet
haha nah no build threads for me on SD, 33 will be up for sale soon anyways i want another R31, QLD raceway is deff on the cards though this year maybe
just for peice of mind this is my mates sedan with exactly same size wheels as mine but hes alot lower and he runs 215 front and 235 rear, with full car load of people it still doesnt rub, also all standard arms
7F7EC3C2-8790-4FAD-ACAA-647F52DBD39E-208
4A0CC30B-4C04-4487-A436-73FF00A4FF24-208
0B599AE8-82D0-49A3-A096-EAE6960BCCA8-208
  • Like 2
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
