....why? it's pretty much the equivalent of a VK commodore... and i don't mean one of the ones that's "maintained" i mean one that kenny uses to thrash the bush!
id say becuase its actually set off quite well
flares, low offset 15" wheels and its having its pants slid off it...
muchos kudos
Laurel is more like a Calais... Cefiro is the Commodore ;)
Fond of everything about it. The stock twin-tone paint, big flares, nice stance and mean rims... ooh and the mirrors :( It's a pig with oldschool flair
um.. has it got interia parts painted red( inside door handle etc)..den it shud b.. had a bride seat too
yeah then it must be. inark needs a backhand slap across the face for painting the interior parts red.. looks so queer. lol the day i got it i painted them all black again!
LOL, yes it was niks and he told me it came from jap like that :P . its a very different car now :laugh:
lol nice work...lol... how did it end up looking? dodgey or mint ?
gud 2 c u moved on from the a31 to another doorian car..how long u planin on keepin?(p.s let me no if u c any jap 4 door projects mr drift car builder :( )
Edited by Dan_J
PM Sydneykid off this forum. takes a while to respond but he's got an awesome reputation.
Check out the groupbuy section also mate.
If you go the stiffer bars, your going to probably need to lower the spring rate back down to 8/6, then the car will sit flat AND grip :P
once i get mine sorted i'll prob be going 7/5 rates.
um yes... like 3cm on front? nd like 4 on bak?
dont know 100%
hahah try about 10cm on the front and about the same on the back.
reason its so much is because the stock bumpers curl under while your-ass sticks it with the lip.
yeah but it looks like the bumper curls under then comes out looks almost the same length... well then again after looking at the pics... think you can get a tape measure up to it if you get a chance?
Edited by 4DoorWhore
Hey Scotty! it's me, CT, from Penang, MY. Remember? There's too many Uras out there... why don't you get one of these.... WONDERS SHADOW. I got this set through the help of a freind in JP.
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
