Joined the 4DR crew two weeks ago... did have an SR in it previously, bought as a bare shell and revived it with some RB Lovin!
Put the car together in time for Drift Attack last weekend and had some fun!
Quick Mods List
RB25 Engine / Box
NPC Twin Plate
Nismo 1.5 Way
TD06L2-20G (Copy)
261 rwkw @ 16 psi
lookin good sam, did my seatbelts make it back down here??
ill post some of my r32 4 door and my mrs r33 4 door when i get some pics.
toff, jangles also has my old purple r32, believe there could possibly be some engine swapping goin on there, lol.
nice haven't seen it about fer a while! , everyone seems to be goin 25 these days , you bought a orange 324d right? , custom trim n stuff?
yeh sounds so tuff, was thinking about getting straight pipes like these
wat u think???
Cheers MackOo :ermm:
Hell yeah, those pipes look sweet! what size are they, 3 inch? Im thinkin of runnin that setup as well. Not sure on how loud it will be with only one muffler though? Cant be any louder than a shit cannon you would think!
Do it!
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 🫠
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
    • But they do so for the other reasons to have a compressor bypass. It's in the name.
