i bought this car off a bloke who imported it for his wife to use as a daily and thats all it did for the past 2 years in australia, i got it quite cheap as it was basically stock, it had a pod filter, trust 3in cat back exhaust with the dori tips, and was lowered a touch. but as part of the deal i gave him a extra grand and got a FMIC kit new in the box, r32 gtr interior, and stock everything, exhaust, air box, suspension etc. and since then ive been tinkering with it as it sits now the mods list is
  • k&n pod filter
  • 3in 1pce dump pipe to custem 3in to 3.5in cat back exhaust with a jasma muffler
  • drift tecks
  • lowered more haha
  • r32 gtr interior
  • trust gear knob
  • new factory replacment gear and handbrake boots
  • exedy heavy duty clutch
  • FMIC
  • Turbosmart BOV
  • cusco strut braces front and back
  • big arse alloy radiator
  • gates timing belt
  • auto spoiler front lip
  • clear indicators
  • JVC deck, alpine 6.5in splits and pioneer 4way 6in's
Soon To Get
  • coil overs
  • r32 GTR front bar
  • rb25 neo turbo
  • remap
  • window tint
  • re-spray, ive touched up the paint best as i can for now but its got a few dents to pull out
heres a few pics from the day i first took a look at the car till now.
I HAD 18IN STARCORPS AT ONE STAGE BUT I HATED THE OFFSET OF THEM
so yeah what do you think of my car so far????????
if you have any tips or ideas for me let me kno id gladly appreciate it
and id also like to say ive done every single mod to this car from the day i bought it, from welding the zorst to making the radiator fit etc etc i love working on my car everyday just tryn to make it work a little better than yesterday :>
Well guys!
The car is back on the road from the hit and run. There still is a little pannel damage, but meh.
Photos from drift day on Sunday:
The Ye Ol Failful rb25de really lacks the power for the smokey burnouts the turbo boys get..
My Fave =]
Edited by GTS4WD
CeJay and GTS4WD nice lookn 4doors, i love 4door skylines, 1 of my brothers mates said to me 1 day whyd u get a 4door? there a piece of shit, so i said to him ll take u for a drive then, took him for a drive and scared the living hell outta him haha hes never been sidways b4, and afterwards i said to him so now what do u think of my piece of shit? and he ddnt say anything and still now a month later he wont talk to me hahahahaha
S2 R32 sedan lights?
pics?
I never even knew there was a S1 or S2 32
Far as I know S2 lights have a line through them, following the bumper line, S1 lights have no line through them. I've been told I have s2 lights
heres a pic of mine. could be wrong but thats what I've been told
you learn something every day...
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
