Item: RB20det powered 180sx.
Item Condition:Car is in excellent condition with the front and being repainted recently after new front bar and gaurds installed.
Reason for Selling: Need a family car
Price and Payment Conditions: price is $12000 ONO
Extra Info:car is midly modified with the following items:
Blitz pod filter.
Hybrid FMIC and custom piping.
3inch dump pipe back exhaust w 4inch tip
Gold ozzy racing 5 spoke rims w new goodyear eagle F1 tyres
( i still have the standard rims will sell with car)
r32 non turbo brake upgrade.
Mines ecu
Apexi RSM
Blitz single solenoid boost controller
boost gauge.
momo steering wheel.
Contact Details:0427231710 or [email protected]
NOW $11 000!!!!
https://www.sau.com.au/forums/topic/87084-rb20det-180sx/
  • 3 weeks later...
its an R33, its Silver on gunmetal grey, it has about 102000ks, mmmm, its just lowered with lovells springs and thats the only modd done. ive tried to post the photos but it hasnt worked so ill email them to you. do you rekon i could get your number off you because ive tried calling afew times and it says the phone is disconnected or if you would like to message me either would be great.
cheers Will 0413600877
https://www.sau.com.au/forums/topic/87084-rb20det-180sx/#findComment-1621733
    • Dissimilar metal corrosion. Aluminium is less noble than steel/iron, and will corrode preferentially when in contact with it and a conductive solution (ie, wet road salt). Tends to suggest that those brackets should be made in steel for a shitty climate like the UK.
    • Here is picture of the rear brackets again seeming to have eating itself or corrode or whatever. Can’t describe it , hope someone could explain this
    • No i am in the uk so maybe road salt etc but checked rear and same story where handbrake cable seems to have eaten part of the bracket. Have emailed alpha omega waiting for reply
    • I've not looked at a GTR without the booster there. Is the hole and mount on the firewall not just the same as GTSt? I would have expected it to be. Nissan don't change panel stampings if they don't have to, and you'd think they'd just order/design the booster to mount to the same place.
    • They have all sorts of "failure" modes. When they are brand new, the can either be very very tight, or reasonably mobile. If they are reasonably mobile, you'll probably have a good start. If they are very tight, then they can catch/grab at every little motion, and they mark the ball or the outer race, tearing off whatever teflon lining is in the outer race, then they can rapidly degenerate from there. If they get wet, they can just rust. They are just steel and will turn red pretty quickly. Water can get in behind them and sit and cause them to become crunchy and then proceed to tear themselves up, as above. Same with grit and dirt. Manufacturers and OEMs of the arms that use them will tell you that because they are teflon lined (well, the good ones, anyway), you shouldn't grease them. If you do grease them, then the grease will catch any passing grit and dirt and hold it in place where it can cause damage. Race teams that have them will lubricate them thoroughly. They will also inspect them every 5 minutes and replace them every 10 minutes, if need be. Some manufacturers of arms will provide dust boots. These can help, but they are seldom perfect, and sometime just make the situation worse, being a place where crap can collect. I have made nappies for some of mine with PVC sheet and race tape, to try to minimise the access of crap. When they wear, you can get a tiny tiny amount of movement between the ball and the outer race. This will make clicking noises. It will also make the arm have "slop" in that the tiny amount of movement available at the inner end of an arm can cause a lot of movement out at the outer end. 0.05mm at 5mm from the pivot becomes 4mm 400mm away from the pivot. If they are too tight and binding, they impede the proper motion of the suspension arm and put loads into it and the rest of the suspension that are not supposed to be there, and can cause failure. Think broken welds, broken threaded sections on the adjustable parts, mounts ripped off the chassis, etc. All of these are possible, which is the main reason why they are essentially illegal on the road in Australia.
