Al, thanks for the info (only noticed your post today). I did read something a little while ago about someone doing the hiflow with VG30 exh housing and getting good results. I'll look into it as well - and yes, it's also added to my confusion :)
porschephile, definately post up the dyno chart from your friends car if you can - i'd be very interested to have a look. I assume that your friend has the GT2835 with the .87 turbine housing?
Also, just having another look at the Nengun website. They have the 2835's on special for $2,560 delivered to Sydney ;)
One question though, they have 2 versions of the GT2835 with A/R 0.87...one with Strong Actuator attached 80mm diameter and the other with 100mm diametre.
Pardon my ignorance, but what exactly does the actuator do and which choice would be better for my application?
One with Strong Actuator attached 80mm diameter and the other with 100mm diametre.
Come on guys - help a novice out :P
Thanks!
Thanks!
The wastegate actuator controls the amount of boost that is pushed through the turbo by pushing excess exhaust gases through the wastegate. The harder the spring is the harder it will be to open the wastegate thus controlling boost.
Not sure which actuator is better, as i am note that technically minded, i usually ask the turbo experts that type of question and allow them to make the decision for me :).
About my combo and your decision, if you could hold off for about 3 weeks i should most definately have a dyno graph to post up. Head has already been sent to be ported, turbo sent to be upgraded, ecu out to be upgraded, cams have arrived, it's all moving quite nicely :D
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
    • Try using Penrite 80W140, has Limslip predosed into it
