as the title suggests??? a mate of mine wants one real bad, but would like to import one as opposed to buying one thats already here, are any models illegible for import to be registered for road use??? or are they all on the n-go list now???
thanks in advance.
https://www.sau.com.au/forums/topic/87120-mazda-rx-7/
I have a series 6 in Black which was personally imported by my friend. It will be registered this week. It also has a series 7 front bar and has just been resprayed. Also has leather and sunroof.
righto, so are you sellin it? or just givin an example of what can be imported?
https://www.sau.com.au/forums/topic/87120-mazda-rx-7/#findComment-1576837
find the right impoter and away u go search then et and magazines and newspapers
yeah we know all that, i was just making sure, coz i'd heard 2 different things so i wanted to clarify which models could be imported etc etc
https://www.sau.com.au/forums/topic/87120-mazda-rx-7/#findComment-1580939
From http://rvcs-prodweb.dot.gov.au/%5Csevs%5Csevsindex.htm :
032/02  MA  Mazda  RX-7  FD3S 09/1999 -  12/2002
Any FD from Sep 99 on can be imported, however there are only 2 RAWS with plates for now so good luck.
cheers mate that helped heaps. :)
https://www.sau.com.au/forums/topic/87120-mazda-rx-7/#findComment-1591468
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
