The a/c compressor clutch fuse keeps blowing in my R32.
At the same time this problem started my control unit display has started to black out.
If I turn it off, then back on it lights up again.
Is the display going out because it senses a problem with the clutch circuit?
I've pulled the plug from the compressor clutch to see if the fuse still blows.
If it doesn't blow I think the clutch must be shorting.
If it still blows then the problem must be in the wiring.
Has anyone else had this problem?
https://www.sau.com.au/forums/topic/87164-climate-control-problem/
The lights issue might be poor connectors on the back of the lcd/control panel. The fuse blowing is most likely burnt out windings, and you are certainly not alone. I'm hoping to get around to fixing mine soon. Jax was kind enough to describe the process here:
http://www.skylinesaustralia.com/forums/in...58631&hl=clutch
Lucien.
  • 6 months later...
Is it easy to replace the windings without having to regas the system?
For those interested -- and for the sake of propagating the guide in a few related threads so its easy to find with the search facility -- here is a guide for removing the windings in-situ on an R32 GT-R (I imagine its much the same across the R32 series and probably for 33s and 34s).
http://www.skylinesaustralia.com/forums/in...howtopic=112597
My A/C kept forgetting it's settings, the fuse kept blowing and my clock died altogether - I had a short. Head unit could also do dodgy stuff from a bad connection, esp if it's intermittent. Go to a sparky!
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
