Does anyone know of any differences in the R33 and R32 GTR manual gearboxes? Particularly in terms of strength, but anything that may be useful.
I'm looking at buying an R32 GTR box with the transfer case disabled and need to know if it's the same strength and a direct fit for an R33 RB25DET box which it will be replacing.
As i understand, once you disable the transfer case the GTR boxes are interchangeable with the RB25DET boxes - but not sure on the R32 to R33 mixing.
Any help appreciated, cheers guys!
Edited by StockyMcStock
https://www.sau.com.au/forums/topic/87185-turbo-skyline-gearbox-differences/
The gears are to all intents and purposes the same - ie strength is more or less the same, but there are some detail design diffferences. These are basically running production design changes between th 1989 GTR design and the end of R33 GTR production. Improvements were also made to the synchro designs, particularly of 3rd and 4th gears. There's also a miriad of other minor changes to casings, etc
interesting..... so is there any real reason the 32 GTR box can't be put into a RWD RB25 skyline? transfer case will not be being used obviously, but do they physically fit?
It will physically bolt up to the engine, of course, but you couldn't do it without the transfer case in place as the shifter mounts to it (for a start - then there's things like the tailshaft which is totally different between the GTR and the GTSt). There was a thread sometime back where someone had started bolting a GTR GB into an R32 GTSt and there were some photos, probably be worth a search.
To be honest tho, I can't see why you'd bother as the R33 turbo gearbox is essentially the same strengthwise as a GTR GB.
yeah the transfer case still have to be there - but you can choose to disable it if the need arises. how, i'm not quite sure actually?
Th GTR box of any series uses the larger RB25-style tailshaft. the only small one is the RB20DET tailshaft yoke which is pretty tiny in comparison. putting the box into an R32 RB20 would need a new tailshaft yoke, but putting it in place of an RB25 would be fine in terms of tailshafts.
i'd normally get an R33 RB25 box too, but this one is quite cheap, certainly cheaper than an R33 box. the R33 box is the one to go for, if you've got the extra $$$ i agree.
You could probably at least partially gut it, but I've never done it. I think this has also been discussed in other threads
Tailshafts are different in the way they attach to the gearbox between GTR and R33 GTSt. GTR uses a 4-bolt flange, but GTSt uses a slip yoke. I also have a feeling the GTR tailshaft uses a different type of attachment at the diff. If the GTR gearbox is going into an R33 GTSt you'd best use the GTSt tailshaft and have the gearbox end changed over to the GTR flange attachment.
Do the numbers carefully. Gearbox might be cheap, but by the time you add in all the extra expense of fitting it, may work out cheaper to buy the GTSt type in the first place and be done with it.
Edited by SteveL
    • Yes to both! Yes to standard ECU and tune, but exhaust is aftermarket. Unsure on brand. Actually have it sitting in at my desk haha! I have to set it up on my laptop but this is a great next step, will do. So I generally try to shift before 4.5K RPM most times. I largely don't do a lot of high-rev driving, but I will take it up to red 1-2x a week max, as I know the occasional "Italian tune-up" is good for these cars.  Oh wow, is this way better than what I'm getting. Does this mean there's a good chance I have an issue?   Thanks for all the info so far guys.
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
