got our ceffy back from getting hks 2530 / cooler fitted and tuned... maxd power 225rwkw which is good..
but major LAG problem... not making any hard boost till around 5000rpm ish... its worse than my 13BT with a 35/40 turbo on it....!!!
just go no midrange and heaps pissed about the result... if i wanted a dyno buster would've got a t51 or something stupid...
the hks2530 is supposed to spool up nice and fairly early, its a ball bearing unit aswell!!!....
HELP!!!
***just checked the computer*** it says nissan on it so i guess its a standard comp unless its been remapped previously (but how would i check)??
***took boost controller off, and connected turbo to actuator (to run stock boost???) boost seemed to come on a little earlier around 4500rpm maybe a little earlier, but didnt test enough (also didnt push too hard as was unsure of boost pressure (no boost gauge)...
anyone else have any ideas??? someone suggested checking a hose for a restrictor? is this the hose from actuator to boost control T piece (then to turbo on other side?)
https://www.sau.com.au/forums/topic/87221-rb20-hks2530-problem/
Somethin is definitely wrong there. You shouldl have full boost at 3000rpm or there abouts. A restrictor would actually make more boost if anything. You sure you aint got leaks somewhere? The compure would have to be remapped extremely poorly to make the engine come on boost that late....
Hmm oh yeah. You sure its a 2530!! haha....
Edited by Busky2k
yeah pretty sure its 2530 if it wasnt though i'd be expecting more power aswell.... :P
i didnt think it'd be remap coz with standard turbo on it felt REALLY torquey!!! (well from what i've been used to) and only had 140rwkw then...
it almost feels 'slower' but with 'more' power :) it just feels like it wants to spool up and take off but its also 'feels' restricted...
"anyone else have any ideas??? someone suggested checking a hose for a restrictor? is this the hose from actuator to boost control T piece (then to turbo on other side?) "
Hud the hose with the restrictor in it should be on the boost controler to actuator side I think that right? guys little help?
If anything the restrictor would cause boost to rise faster, by smoothing/slowing airflow to the WG actuator thereby delaying its cracking open. Does the rod to the wastegate flapper have any play or is it rock solid ? Can you move it fore & aft by hand ? I can't think of anything else offhand that would cause your prob...
2530's on the rb20's don't get all their boost in by 3000rpm, the stock turbo does yer. :rofl:
Its around 3800rpm loaded up on the dyno for around 1.1bar.
Edited by Cubes
What about checking all cooler piping hose clamps and see if the bov is shuting.Could be a boost leak.
Just to compare I have a HKS GT2535 on the good old 20 and get 17psi boost by like 3500rpm in 3rd.Pulls hard at @4000rpm.
2530's on the rb20's don't get all their boost in by 3000rpm, the stock turbo does yer. :huh:
3800 rpm on a dyno? Thats pretty shocking response from a small turbo!! On an SR20 you'd get full boost much sooner than that. Loaded on a dyno you'd easily get 1 bar at 3000 RPM! (So I naturally would have assumed the same for the RB20)
The RB20 has lots of smaller puffs instead of less big puffs.
Not good for spooling a turbo but good for top end, if the head allows the airflow.
As Robo with his RB25DET stated in the following thread.
http://www.skylinesaustralia.com/forums/in...showtopic=84926
2200rpm = 6.5psi
2600rpm = 11.6psi
3000rpm = 15.8psi
3400rpm = 17.3psi
3800rpm = 17.9psi
4200rpm = 18.7psi
4600rpm = 19.1psi
5000rpm = 18.5psi
5400rpm = 17.4psi
5800rpm = 15.8psi
6200rpm = 13.8psi
Edited by Cubes
just curious as i was thinking of getting one of these turbo or a to4 hydrid. Are you still running stock injectors and if so how much boost can you run the 2530 with stock injectors and just 040 fuel pump as i won't be able to afford injectors for a while and you didn't mention injectors in your list
other supporting mods
hybrid GT spec FMIC
hks 2530
hks FCD / standard comp
turbosmart dual stage bleed valve ( possible problem changing soon )
full custom zorst / no cat or mufflers...
apexi pod
apexi bov
Theres something deff not right there!
I find it very hard to believe you can get 225rwkw with std ecu, inj, afm. In fact i think almost impossible.
I have a 2535 full boost is 18psi @ 3800rpm with poncams too...
looks like it may have been the non stock rubber hoses (no restrictor) from the actuator to the front of the turbo housing or the actuator was stuffed.
Im leaning towards the hoses as the actuator(stock one) looked fine we swapped both over over anyway seemed to turn the ceffy into a smoke machine though!!!
if you had seen the smoke I'm sure you would have thought it was making more than 225 rwkw
Make sure the RB T3 and SR/GTR T25 2530s are the same turbo...its possible they are slightly different turbos, with different A/Rs ?????
The GTR/SR style 2530 has a different (smaller) turbine cover than the RB20/25 style 2530.
My guess would be you have either premature wastegate opening (most likely) or a boost leak in the inlet system (less likely). Try disconnecting the boost feed to the wastegate actuator, that will tell you how fast that turbo/engine combo can possibly build boost. Be carefull though, it is only a test to see how quick the boost builds, use the throttle to stop it overboosting ie; back off when it gets to your max safe boost level.
I used that method on the Stagea, so I knew exactly how fast the standard turbo would build boost (10 psi at 2,250 rpm). Then I could tune the IEBC to achieve the fastest boost build.
:( cheers :)
HELP!!!
I'd say tuning...
My car used to be similar, with a chipped ecu and stock injectors
It had little timing down low, making it feel very laggy
Picked up 45rwkw through the midrange after I had it re-tuned with bigger injectors and PFC, I'd say by the sounds of it, and the power its making, there are no leaks etc, its all in the tune
Where was the dyno done?
Chris
i have had it dyno'd since and it seems that i've gained 200nm torque in the midrange... still a little laggy!!
might try putting a 'kink' in the actuator line to create a similar affect 1400R did by tightening his hks actuator a lot more... and resulted in boost coming on earlier ( i know dodgy fix but may work... )
    • The steering wheel on my 97 s3 gtr is a little bit worn out, so im on the hunt for something mint. I notice that this type of steering wheel is on several other nissan's of the era.  Does anyone know if their all identical, or are there slight differences? I feel like gtr tax applies to anyone selling one, but if it comes from any other car the price is much less, even though its the same design.  Chat gpt says the material for the gtr is slightly different and it says gtr on the wheel, but every pic ive seen it just says nissan.
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
    • I remembered wrong, but was close though 1Kz setting because those Jaycar SSRs don't go any faster, 1x pump per SSR with flyback diodes & heatsinks. In saying that, the heatsinks are overkill. Just on an alloy plate is more than sufficient. You'll find without a flyback diode, your SSRs will heat up big time and also die prematurely.  I've been running the two same SSRs since the last motor, no issues, car does 2 hour straight drives in summer once in a while and gets punished on the track. Nothing melts, no hot messes, etc.
    • Hmm. You're probably best off working out what the lobe centreline or even the LSA is for the stock cams, with VCT OFF. That's bound to be out there somewhere. Then, work on the assumption that the Kelford centreline is probably the same, and wouldn't be more than a couple of degrees away, if it is different at all. I'm very surprised that you needed to adjust the exhaust cam by 5° to get it on spec. That screams there's another problem somewhere. Anything from the belt being 1 tooth off (how many degrees is one tooth worth?) to simple user/measurement error on the degree wheel. I say this because Kelford, like most quality cam manufacturers these days, does a pretty good job of actually making the cams to spec, not relying on patching it up afterwards like we had to do back in the 80s.
