  • Replies 40
I can remember my first time.... I was about 11 or so.... Back when willowbank raceway only cost about $12 for adults and $5 for kids or something like that....
I was struck with the awsome power... Back then there were only running 6 second passes and a low 6 was fast. I can remember going to every drag race meeting with top fuelers from then on. Until about 2001 when they put ticket prices through the roof....
But i did go to winter nat's this year at $45 a ticket.... (just for one day on the hill) First time back to top fuel heaven in 4 years and i reckon their even louder then ever....
A Definition of Acceleration.
* One Top Fuel dragster 500 cubic inch Hemi engine makes more horsepower
than the first 4 rows of NASCARS at the Daytona 500.
* Under full throttle, a dragster engine consumes 1-1/2 gallons of
nitromethane per second; a fully loaded 747 consumes jet fuel at the
same rate with 25% less energy being produced.
* A stock Dodge Hemi V8 engine cannot produce enough power to drive the
dragster's supercharger.
* With 3,000 CFM of air being rammed in by the supercharger on
overdrive, the fuel mixture is compressed into a near-solid form before
ignition. Cylinders run on the verge of hydraulic lock at full throttle.
* At the stoichiometric (stoichiometry: methodology and technology by
which quantities of reactants and products in chemical reactions are
determined) 1.7:1 air/fuel mixture for nitromethane, the flame front
temperature measures 7,050 degrees F.
* Nitromethane burns yellow. The spectacular white flame seen above the
stacks at night is raw burning hydrogen, dissociated from atmospheric
water vapor by the searing exhaust gases..
* Dual magnetos supply 44 amps to each spark plug. This is the output of
an arc welder in each cylinder.
* Spark plug electrodes are totally consumed during a pass. After
halfway, the engine is dieseling from compression, plus the glow of
exhaust valves at 1,400 degrees F. The engine can only be shut down by
cutting the fuel flow.
* If spark momentarily fails early in the run, unburned nitro builds up
in the affected cylinders and then explodes with sufficient force to
blow cylinder heads off the block in pieces or split the block in half.
* In order to exceed 300 mph in 4.5 seconds, dragsters must accelerate
an average of over 4G's. In order to reach 200 mph (well before
half-track), the launch acceleration approaches 8G's.
* Dragsters reach over 300 miles per hour before you have completed
reading this sentence.
* Top Fuel engines turn approximately 540 revolutions from light to
light!
* Including the burnout, the engine must only survive 900 revolutions
under load.
* The redline is actually quite high at 9,500 rpm.
* Assuming all the equipment is paid off, the crew worked for free, and
for once NOTHING BLOWS UP, each run costs an estimated $1,000.00 per
second.
* The current Top Fuel dragster elapsed time record is 4.441 seconds for
the quarter mile (10/05/03, Tony Schumacher). The top speed record is
333.00 mph. (533 km/h) as measured over the last 66' of the run
(09/28/03 Doug Kalitta).
Putting all of this into perspective:
You are driving the average $140,000 Lingenfelter "twin-turbo" powered
Corvette Z06. Over a mile up the road, a Top Fuel dragster is staged and
ready to launch down a quarter mile strip as you pass. You have the
advantage of a flying start. You run the 'Vette hard up through the
gears and blast across the starting line and past the dragster at an
honest 200 mph. The 'tree' goes green for both of you at that moment.
The dragster launches and starts after you. You keep your foot down
hard, but you hear an incredibly brutal whine that sears your eardrums
and within 3 seconds, the dragster catches and passes you. He beats you
to the finish line, a quarter mile away from where you just passed him.
Think about it, from a standing start, the dragster had spotted you 200
mph and not only caught, but nearly blasted you off the road when he
passed you within a mere 1,320 foot long race course.
... and that my friend, is ACCELERATION!
The rear slicks used on these dragsters aren't much good after 330 MPH. That's why the NHRA keeps downgrading how much Nitromethane can be used in the fuel in order to keep the trap speeds down.
If the NHRA allowed them to run 100% Nitromethane and crank up the supercharger overdrive (or allow fuel injection) then the ETs and trap speeds would be much more spectacular.
Edited by MrBlonde
Yeah, it's running an RB26DETT bored out to 500 cui, with Nismo N1 Rootes supercharger at 50 psi and stock Nissan twin magnetos. He added Nulon octane booster to bring it up to 90% nitromethane.
Funniest post ever!
Incidentally, the 4.61 pass looks to have torched the heads at the 1000' mark. This and the fact that the car was still running on the NHRA spec'd 85% nitro mix is insane!
Plenty more to come I'm sure.
Adrian
Very nice effort, every time i go to see the top fuelers they blow up half way down the track and still manage to roll through for a 5 to 6 second pass.
What was the event there, no one was in the crowd?
Test and tune for the EAST COAST NATIONALS
Thats incredible.
First time I ever saw a top fueler run I was standing about 4m away at the start line at willobank, both launched and I thought my whole body had been samwiched between two massive vibrating sanders. My eyes went completly blury, I was phisically pushed back 1/2 meter. then there was the sound - completly out of this world.
I stood there in a strange state - a mix between completly dumbfounded and laughing like a school kid. That is something I'll never forget.
Both cars went to post sub 5 second passes.
There is nothing like a full power run from two top fuelers!
If you have never seen the top fuelers live - go do it!
i've been watching these on tv for a while... is there anywhere/time you can see them in melbourne? :D
No chance. Vic and SA don't have any drag tracks that are ANDRA-sanctioned. They don't meet the safety requirements of ANDRA either.
Best chance would be to fly up for this weekend's AC Delco East Coast Nationals at WSID 16th-18th Sept.
The two fastest passes are both from rocket power dragsters. These racecars are not recognised by NHRA or ANDRA for competiion.
The fastest ever pass was in 1977 by Kitty O'Neill 3.235 seconds @ 412.50 mph.
In 2002 Slammin' Sammy Miller ran 3.583 seconds @ 386.26 mph.
damn. i figured it would be something like that. cheers.
    • Yeah it is really until until you get a feel for it....then it is easy. Which is no use to you really. I'd buy that torque wrench. One thing from sure, many (most?) tyre shots overtighten the f**k out of wheel nuts, so don't worry if they were tighter when you tried to take them off compared to when you do them up. I've had some crazy tight ones come back from shops, quite apart from the potential damage to the thread, I can't see a smaller person taking the wheel off on the side of the road
    • Hey mate, thread dredging hahah To answer you directly, yes I had my itbs oversized and custom butterflies etc made by EFI Hardware in Sydney back around 2017-2018 if memory serves. My setup had a vast amount of other changes too though, so no direct comparisons unfortunately. i went from oem itbs, HPI manifold and internal gate hks 2835 pro S; to 49mm itbs, cnc port matched Nismo plenum, RB25 Neo lower runner adapter hand port matched, r31house v2 Takoashi MAX equal length twin scroll manifold with twin 38mm tial gates and a FP HTA3076 with 1.01ar twin scroll real hosing. feom power Fc to a link fury wired by 12volt, r32 gtr fuel tank conversion with frenchys twin 460 / surge tabk fuel hanger combo kit, 1659cc injectors, full 4 inch turbo back stainless exhaust, Z34 6 speed, Tomei 2way with 4.3 final drive and a ton of other shit. ive posted elsewhere here with complete run down, but here's a graph from its initial tune with no boost control on, 20psi gate springs only and e85.   7542AE72-DA92-4E0B-8660-B0940FEA7F24.mov
    • On sale mate, $55. Sorted. https://www.supercheapauto.com.au/p/toolpro-toolpro-torque-wrench-1-2-drive/565734.html?utm_content=paidsearch-pmax&gad_source=1&gclid=Cj0KCQjwytS-BhCKARIsAMGJyzqYEnwWmhWf6gxTST_Nz06Gd2VePgyvL7lh6PWrQtbjXTsI6TqSCLEaAuaCEALw_wcB&gclsrc=aw.ds
    • Slap it and say it ain't going no where, you'll be fine.
    • So the whole rb25de neo setup was a tiptronic setup and i swapped everything over to my rb20de neo setup and yes even the cluster of the rb25 was swapped over.
