Ok guys, we need to have a discussion about the next possible skidpan day.
First things first. 16 people, full day, $150 each.
We do the skidpan as per usual for half the day, but then the LVMA for the other half. Let me give you an idea of the LVMA. Its basically a 100m x 100m bitumen area. It has witches hats on it, and little things that let water out. We do brake tests, slaloms, timed track runs. You get to go all out, the only thing you are worried about is putting in the quickest time you can. There will be points kept, with overall positions at the end of the LVMA.
The usual instructors will be there, and its a full day of going mental in a legal environment. Instructors are very good drivers who also egg you on (tony).
Its not hard on your car. The skidpan is covered in diesel and water and is easy on revs, temperature, tyres etc. LVMA is also easy on the car. Makes your car dirty though. If you are worried about that, dont come. If you want to go mental, or bet better at driving, come on down.
I have been to a full day session with Performance Forums, and 2 half day skidpans which I have organised.
Guys, talk to me about the price, the event, questions about instructors or possible damage, and who really wants to come. It will proabably be in feb or march on a Sunday.
https://www.sau.com.au/forums/topic/8727-skidpan-day/
  • Replies 135
I would be interested, but hopefully by then I'll have sold my car. $150 is a bit of money, but I guess it is worth it. I guess it will depend.
When does money etc, need to be in by? Also for the skidpan day, would there be people demopstrating/instructing on drift etc?
Thanks for all the hard work oorganising Slip ,keep it up mate!
https://www.sau.com.au/forums/topic/8727-skidpan-day/#findComment-130619
ill demonstrate :D
as i said in the original post there are at least 3 instructors, who are all there to get your drifting ability, confidence, speed, and car control as good as they can by the end of the day. most people just take the instructors for a quick ride, then the instructor might drive their car to show them how its done in their first session. after that you can just go by yourself (or drift with 4 passengers like i have to sometimes as people like GARY pile in) and learn as you go. Very relaxed atmosphere. $150 is worth it, trust me.
https://www.sau.com.au/forums/topic/8727-skidpan-day/#findComment-130657
after feb ill be in, im a little short cash wise atm
sounds like a shitload of fun, a chance to learn to drive better... which id say i could probably use :D
edit :- im assuming the hardest thing ur gonna hit is the cones? and gettin my car dirty, well it does that with normal driving :S damn dirt driveway
https://www.sau.com.au/forums/topic/8727-skidpan-day/#findComment-130673
Guest
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
