  • Replies 135
theres so little friction that theres not a lot of wear on the tyres (relavitvely) but if you can put some cheapies on the back, do it.
We have raced 1 on 1 round the skidpan before, each person started half a track away from the other, and it was first back to the starting point after 3 laps, but it turned into a grip elimination race which was poo. Dont know if we will do it again. We do time trials for sure :P
does not sound like the video venue to me.
https://www.sau.com.au/forums/topic/8727-skidpan-day/page/3/#findComment-149027
We are going to video as much as we can....
pete (aka revlimiterboy) will be back down to dorifto the track one handed again....
and I am in training so definatly count two cars from rockhampton.... Jays is a bit of an issue... have three cylinders and all.... don't know if the water will get into the hole in his piston....
anyway.... we are definatly in... no questions asked.... and we'll have a support crew big enough to rebuild a motor if needed.... should be fun... Is it worth going to broadwater for a cruise after the meeting.... I reckon it would be definatly worth a look but I hear the cops are gnarly these days.... not that we want to play up or anything....
and yeah hopefully there will be heaps of good video action....
looks like MRE has got the dorifto down to an art....
incase you can't tell I just can't wait to go playing legal dorifto for safe long amounts of time.... AWSOME>>>
https://www.sau.com.au/forums/topic/8727-skidpan-day/page/3/#findComment-149275
hey slip...
are we still waiting on a date....
can you try to make sure it doesn't clash with the SR20 day...
actually... you should try to make it so that one day it's your wet skid day and the next it's the SR20 day....
just there is a huge crew coming from rocky and we are planning on coming down twice... but if it was at all possible that it could be just one weekend... it would be awsome... cause everyone would come from up here....
but yeah i understand it's all due to availability and maybe that means that some guys don't want to do both events so close together....
although from what I can make out MRE won't be scared...
just pete wants to go to the dry day....
a whole heap of us want to go to the wet day and it would be a shame that most of us can't make both....
just see what you can do slip... thanks a heap....
https://www.sau.com.au/forums/topic/8727-skidpan-day/page/3/#findComment-157650
I am told it is at the end of march at willowbank raceway....
but please don't ditch your event because of it.... I really want to go to the wet day for the fun.... I don't like the idea of breaking my car in brissy and having to find a way home....
where as pete is totally hooked on the idea of destroying his new toy at the SR20 day..... go figure??!!
anyway.... I found out about it because it is on the events callander of the raceway.... I think MRE should be able to hook you up with some dates...
please try to organise them so they are the same weekend and there will definatly be some very excited rockhampton import boys cruising in brissy.... we would love to organise a saturday night cruise with you boys as well.... if we are going to be down there we better make it a huge weekend eh??? so if we can organise it all it would be tops.
https://www.sau.com.au/forums/topic/8727-skidpan-day/page/3/#findComment-160276
I'd love to come and have a go but the almighty $$$ has a hold of my pocketbook (figuratively speaking) :) .... I'll probably come and spectate instead. I've been browsing the forum for a while now and have only met Slip so far.
Look forward to meeting everyone...
46n2:burnout:
https://www.sau.com.au/forums/topic/8727-skidpan-day/page/3/#findComment-161520
Guest
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
