oh well....
I will definatly be there.... so please don't knock me off the list... just the rest of the crew won't have their cars ready till the end of march...
I'll come down twice.... so maybe we'll just have to organise a cruise saturday night which will be the 29th of March....
what do you think guys???
i'll try to get Jay excited about rebuilding the 180.
we ripped it down the other day and although there is some dissagreement in the party.... I think we will just get away with a hone and a new piston...
actually if you want to check out the photo's of jays piston check out the Wasteland... squizzmobile in hospital/Spank HQ and check out page 55... i think.... it's around there anyway...
it did do a nasty job of destroying the piston....
anyway slip... it looks like it will be just my car in the skid pan day... and I am still really really really looking forward to it....
we'll still bring the crew down sometime... probably on the 29th if you can get some sort of cruise happening it would be awsome...
https://www.sau.com.au/forums/topic/8727-skidpan-day/page/4/#findComment-163463
  • Replies 135
Ouch, cheap shot :)
Dunno how it'll affect times around Mt Cotton (probably slower, more dorifto!) but the suspension should stop 'incidents' like the one on the way out of Gary's place (tandem drift over the crest of a hill) from being quite so bloody scary... by the way, did Gary tell you his exchange students this time are two 21yo French girls?
/me waits for 'ooh la la' comment :D
https://www.sau.com.au/forums/topic/8727-skidpan-day/page/4/#findComment-168441
I'm from the gold coast and intend on gettin a skyline within the next year (still at uni atm). Got directed here by iNark (mate of mine from melb) who's a bit of a regular. So far the forums have been really helpful and I'd love to come along and check out the qld crew goin nuts and meet some of you :)
Be great if it was March 2, got nothing planned that weekend. So yeh, hopefully me + 1 or 2 mates will come up and have a look once its all confirmed.
https://www.sau.com.au/forums/topic/8727-skidpan-day/page/4/#findComment-169810
well keep us posted...
we are all super keen by the sounds of it...
so it's your mission (should you choose to except)
to promote the dorifto...
anyway still letting you know I'm keen....
and if it's getting to late for early march the 29th is calling you slip...
you know you want to .... (the 29th march)
https://www.sau.com.au/forums/topic/8727-skidpan-day/page/4/#findComment-170068
Guest
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
