Heh. Maybe you should break out the steel wheels, or better yet, how about four GT-R space savers. That would be an interesting look on the track :) In fact its almost worth trying to borrow a couple of space savers just for a photo op.
Re: SSR forging technique (the general URL was posted earlier, this is the info specifically about the construction):
http://www.tirerack.com/wheels/ssr/ssr_info.jsp
Apparently my SSR Integral wheels weigh 8kg for the front 17x8" and 8.2kg for the 17x9" on the rear.
There is a website something like www.wheelspecs.com or something that has weights and other specs for heaps of different wheels.
Ok I don't know the weights with tyres but this site has the wheel you are looking at.
http://www.wheelweights.net/
This wheel is about 9kg (ish) - could only find the weight of the 18x7.5 which is 22.3lbs... so I just reduced it a bit. This is a great looking wheel!!! And a great price!!!
The 15" S14 wheel is about 7.9kg... but obviosuly there is alot more rubber attached when you put tyres on.
If you take a look at the more expensive Jap stuff, eg. Gram Lights 57S in the same size (17x7.5) it is 7kg (ish). Also a cast wheel (unless you go for the PRO version) and costs about $500 or so each wheel. So you basically pay for the weight reduction. Maybe they are stronger but I don't think you sound like the person that is taking his skyline to the track...
Hope this helps
Cheers
Adrian
Hehe, that was the whole point of the exercise of trying to find lighter rims... as i am starting to do some sprint days, and want some lighter rims for the benefits they give to a track car...
if i was purely after looks, the weight wouldn't bother me
LOL sorry - must have missunderstod... If you got the money then go the jap rims :)
I did :):)
  • 2 years later...
Don't know whether this helps, but I just weighed a standard R32 gts-t rim + tyre I have here and its 18kg.
Wow, I'm a little surprised as I thought of that wheel as looking quite light. So are those wheel cast then? A wheel weight website somewhere said the 32 GT-R wheel is 16lb/7.2kg, but that's just the wheel. Anyone weighed the 32 GT-R wheel with a tyre mounted? (Obviously varies with tyre, but for a rough idea?)
I had some 17" ROH Adrenalines that weighed 19kg with a tyre, and I thought that was pretty porky, but maybe not that unusual? Current ones are 15kg with tyre, and I was casting about for something potentially lighter, hence wondering about 32 GT-R wheel/tyre weight.
wow, diggin up a 3 year old thread, nice :)
what u have to understand is that a wheel may be small in diameter, and thus weighing less than say a 18" wheel, but the tyre to keep the same overall diametre of the wheel and tyre u need to run a higher profile on the smaller diametre wheel, this means the tyre weighs more.
the GTS-t wheel is cast yes, the GTR wheel is forged, weight wise there is not a whole lot of difference, the GTR wheels weighs a bit less, but remember the GTR wheel is 8" wide and the GTS-t is only 6.5" so its not really a fair comparison.
remember, weight is relative to the size and strength of the wheel, no point having a really light wheel if its weak as piss and too thin to fit a decent size tyre on it. 19kg isnt overly heavy, but id imagine the wheel was something like a 17x7ish? to give u an idea, R33 GTR wheels (forged)weigh around that, are very strong and rigid, are 9" wide, with near new 235/45 tyres on them. they weigh around 9kg on there own without tyres.
ROH's arent a particularly expensive wheel and use a pretty standard casting technique.
My 18x8.5 TE37's weigh in at 8kg...very light for an 18" rim in my opinion...I think the LMGT4 is 1 of few that is lighter than TE37's inch for inch...
I expect the 18x9.5 rears I'm getting to be 8.5-9kg, but I'll have to wait until they're here to weigh them
So 32 GT-R wheel with tyre would be around 18kg or so anyway? Anyone weighed one?
(The ROH was an example of a fairly nasty wheel, that's why I was surprised the GTS-t wheel was nearly the same weight, as the ROH looks like it has lots of excess material, but the GTS-t wheel looks pretty clean.)
the casting technique is ultimately what determines the weight, the design does play a role, but not usually as large as the manufacturing technique.
the weight of a tyre and rim will vary by a few KG's depending on tyre size, tyre design, tread left etc etc so u really cant compare. plus the GTR wheel will usually run a wider tyre as well so theres extra weight.
There can be more variation in the weight of the same sized tyres of different construction than the weight of a one forged rim verssus another forged rim. A new tyre with 8 mm of tread weighs more than used tyre with 5 mm of tread, let alone a worn out tyre with 1 mm of tread. Take a look at what is written on the sidewall of a tyre, research how many steel and/or kevlar belts, shoulder and sidewall construction, plycord, bead filler and wires and the chafer. Saving 1 kg by spending $800 more on a wheel and then using a tyre that weighs 2 kgs more is not very cost effective and may do nothing for performance at the same time.
Cheers
Gary
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
