1st pic is the v8 short motor just after i removed it from the engine bay( i only just thought of takin pix at this stage)
2nd is the empty engine bay....lots of room hey :huh:
3rd is one stripped and cleaned cylinder head
4th is the inlet port, nicely cleaned up...
5th is inlet port from valve side
the plan was just to give the cylinders a hone, fit the new rings, bearings, cam and lifters, reseat the valves and throw it all back in, but....
https://www.sau.com.au/forums/topic/87298-picture-thread-for-c210-v8-rebuild/
number 7 bore is far too pitted and scored(pic 1 and 2) to hone out, so the block has to be sent to Trapnell Race Engines to be bored out another 20 thou(total of 60) dammit, now i need to take the rings back and get bigger ones,AND buy pistons....not happy jan.
pics 3 and 4 are the valve spring compressor i made, because the one that i bought bent when i tried to use it. Damn aftermarket double valvesprings.:huh:
meh......to be continued.....
Trapnell ahahahaha.............. your going to be waiting a while, they have taken 2 years with my bros engine so far and it still isnt done.
Hope it all turns out well tho.
They did the heads for it and we didnt wait for too long. They have been pretty good actually which is nice.
Rang them just before to get the quote to bore out the head for jase and they told me 1-2 days and they will have it done by the end of the week.
We have been told that they can be alittle slow, but so far so good for us, which is lucky, cause we need the v8 running asap :P
Sucks to be your brother then, because i put my heads in to be machined, i got them back the next day.
Then i put the block in on wednesday to be bored and have the new pistons fitted to the rods......picked it up on friday, all work completed.
All work was done by the time he said it would be ready.
I will definately be going back there.
Update...new timing chain cover was in order, and i also bought a speedmaster hi flow, semi hi-rise manifold.
pics-----fitting piston rings...
post-7874-1127472247.jpgpost-7874-1127472277.jpgpost-7874-1127472207.jpgpost-7874-1127472311.jpg
Ok cause Jase has been alittle slack ill add a quick non-pic update.
On sunday we seated the valves (i did one of the heads and im rather proud of myself), finished the heads off and now the motor is looking more like it should.
Fingers crossed that today we might be able to get the motor in!
The v8 is finished.... YAY.
So i will finish this and update you all on what has happened since the last post.
This is as Jase was painting the sump in our infamous Kermit Green... fun afternoon with the paint cans nozzle being poo and annoying jase. In the end it looked good tho.
The motor back in one piece...
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
