so the HKS GTR only has the pods to make them sounds good?
and those 9s GTRs also, no performance increase from pods?
They probably found it easier to fit their upgraded turbo kits with pods instead of the airbox + the pods look and sound cool
Edited by gtst25
  • Replies 72
but with the forward acceleration of the car colder air from infront of the car should go into the pod
A car is designed so that there is a low pressure area behind the radiator (the engine bay). This allows the great majority of the air to pass through the radiator and cool the coolant. In the process this air heats up. This is the air that is sucked in by the pods.
This is also why stock air box's have their snorkle fitted up tightly behind the front head light. If they were to just sit it there it would be of no use as the air from the radiator will contaminate it.
Valid point, but is the pod in that low pressure area "behind the rad"?
Im not saying your wrong but thinking about it I doubt that the air will get all that much kinetic energy transfered to it to keep the same momentum as the car (thus the pod) to allow a majority of it to be sucked in my the pod.
Sure the turbo will create a great amount of suction, but by the time it effects the area where the heated air that cooled down the rad is most of that air should be on its way out of the engine bay or be hit against the engine and bounce elsewhere, some to the pod and most of it elsewhere in the bay...
Eitherway I still am a air box fan, and believe even with a pod mostly cold air will be sucked in.
At the end of the day there is an intercooler to cool the intake air, and if it is a 30+ degree say its just stupid to use drive any performance car (especially turbo) at its full potential, but I think the pod sucking in hot air, however little amount of air that is, is insignificant on a effectivley intercooled intake system...
-Jez
-Jez
There is no cold air in an engine bay, its damn scorching under there, anyhow i used to have my pod unshielded right up kissing the passenger headlight and it was terrible, performance was always up and down, so moved it into the bumper bar, and power is now much more reliable, at night its spectacular, i have a just jap front mount so cant use standard air box
So your saying that the WHOLE engine bay is a low pressure area...
So where do you think the hot air from the radiator goes? The air is sucked out the bottom after swirling all through the engine bay. Admittedly there is a small amount of air coming around the headlight, and a clever guy will fit a snorkel into the front bar to use a spare hole to force some cold air in but without a really well constructed chamber there wil be heaps of hot air sucked in. Calculate 2.5L running at 6000rpm + 14psi of forced induction (so double the previous number) and then calculate the number of engine bays at around 300L that is sucking through each minute. Start to get the idea?
It's not uncommon for ambient temps in the street car engine bay to get to over 70degC and when an exhaust is glowing dull red that is about 700degC.
On my track 25t I measured post turbo temps of over 75deg off an enclosed pod with a highflow running 14psi and 220rwkw. After the Hybrid Monster 800hp FMIC it had dropped to 28 deg on a 27deg day. Imagine if it had been sucking 70deg air in.
On the GTR33 the airbox has an extra inlet through the side of the bay inside the guard so it will run extra power, but I'm currently working on a simple mod for the GTS25t airbox to take in extra air through the top with a snorkel to draw what cool air can be had.
i used to run my pod down in the front bar, never had any issues, cept the pod got dirty quicker
certainly never had any issues with airflow at speed (that i noticed anyway)
now have pod back in engine bay, sealed off nicely
i believe the sucky sucky noises give me an extra 20rwkw (in my mind)
I'II show u mine geoff in in a few days if I get the chance. I have mocked up a new snorkel to replace the stock one...the inlet will be much wider, nearly to the radiator cap. in addition the snorkle itself will be bigger to add some volume to the intake side. I was gonna make a new lid, but decided this was enough at this stage to keep it looking stock. But I new lid would be good also.
You don't believe so?
Compared to the air pressure on the nose of the car yes... the whole engine bay has a lower pressure.
I totally agree theres a significantly lower pressure compared to the nose of the car. Hence my theory on its momentum. My tired thoughts have been misconstrued. So never mind about me.
Totally agree, running a good source of cold air will help, but as youve mentioned a good FMIC as I also mentioned will make more of a difference in the end.
Ne hoo...Looks like Ive had my ass handed to me.....so Ill shut up now.
Nah, you had some good thoughts there. They just needed to be followed through a bit more and the links would have made you see what happens so well done on that. Certainly not about handing anyone ass or any other piece of anatomy.
A good sized FMIC will make a difference but needs help. I remember my stock side mount on 12psi was seeing over 60degC on a 29deg day but I could get that down to 34 with the IC water spray on. As they say: "you can't polish a turd". :)
Like I said, 130am ramblings......ne hoo, Im thinking about getting some temp senders under the bonnet when my cars done and on the track, see whats happening under there, cous If I can fit the R32 airbox like I had perviously in my R31 with the new turbo and pipe work then I will, if not I have to settle for a pod :O
just for every1s info.
I ran more power up today and had an issue with the stock rubber intake hose from the airbox to the turbo. Essnetially under hi load the rubber would collapse...obviously the air box was restricting this too much.
I replaced the box with a pod for the run which sorted the issue.
So essentially what I deduced was the stock air box and snorkel simply couldn't supply enough air over 1bar or around 250rwkw. This is with a trust hi-flow pannel filter.
Pod filter...no dramas at all. Hmm...I could replace the rubber with a al intake pipe to force suction. I think a new lid or ported stock box and bigger snorkels is in order.
So there u go.
Actually,on the subject of the inlet hose,has anyone tried cable ties every 50mm around it?I think just by doing that it feels just a little harder to squash.Havn`t had any issues since.
So there u go.
Never thought of it that way, but did it make any less power with standard box in place?
So there u go.
Now what would be nice to see is how much power less (if any) it would make if you were to leave the stock air box and replace the afm -> turbo pipe.
OR.. If you were to open up the std box and feed a decent cai in to it.
But yes.. Any dyno sheets we can see a back to back? Would be interesting to see where it began sucking in.
i run panel filter on my GTR.. its better than pods.. just cause GTR has too much crap and generate far more heat than an RB25 would. street cars i mean. unless u cut and re route air to the LHS of the engine bay its pointless.
having said that my brother just put on a DRIFT pod on his GTT. it sounds harder. doesnt feel quicker than the airbox.. and gives a gay drone noise at 1500rpm.
we measured the surface arear of a Trust mushroom pod we have at home and it is larger than a panel filter. not to mention the equal distance between funnel and filter substance.. wher as a panel filter is flat and the closes point is the LHS of the panel filter. so u would have different pressure rates on the sides of the filters unlike a pod which is more even.. do u guys follow?
i would rather an ARC AIRbox than a pod or stock panel filter..
thats what I was gonna suggest, run a steel pipe to the box, Im going to try this on my new setup and see how it goes
    • The spray cans were in the "Kiln" room whilst I was preping the parts,  so probably around 2 hours to get them warmed up, the kiln room has 3 small ovens running at 100°c, 3 medium sized ovens running 100°c, and the large one I used running at 80°c, the room itself was about 28°c, I also spent a bit of time taping up the parts in the room as well, and by the time I was done I would assume that the parts were around that 28°c As for power, I expect a couple of Killerwasps up high would be achievable with the current mods, I'm still running the MZR 2.0 intake and throttle body, and there is a slight mismatch with the 2.0 intake (smaller) and 2.5 intake ports (larger) on the head, this intake is matched and specifically designed to fix this issue with the ports mismatch, the throttle body is also a couple of mm larger, OEM is 65mm, the Bosch is 68mm In the end it will look "prettier" than the molded plastic thing that is the OEM MZR 2.0 intake As for the LSD, it's the OEM Torsen which works fine for what I use the car for, plus, basically no maintenance apart from the occasional oil change
    • I was at Tunehouse in Marrickville (great team over there really know their VR's) , and I spotted this Very clean R35.
    • Mate , I have the same issue right now with the exhaust noise , if you can tell me what your local guy did , I'll talk to my guys and see if they can do the same. Power is good but it just too loud when put it down.
    • The other trick I've found with wrinkle black is to put the can in hot water for a bit to warm the paint up, and to pre-heat whatever you're painting. It'll be interesting to see if you pick up any power with the intake, following with interest. Got a proper lsd for this?
