Fri 14&29th Oct Drive Day, At The Creek $120
Update?
Niel's car had some slight teething issues.
The weather was perfect for spectating.
The pits/track was absolutely packed with Historic Touring Cars all guzzling about 20L of fuel a lap :(
When their weren't any cars on the track all I could hear was the drag cars at WSID ripping it up :)
I met 1 of the Lebanese A1GP drivers and had a snack with him (that guy has way too many HSBC credit cards :))
  • Replies 134
yeah there would have ben lots of the Historics there as there was the biante meet on sunday. unfortunately we didn't run spencers car as we got booted off the entry list! they had oversubscribed and gave preference to cars that had contested every round so we missed out. they gave us free tickets as compo, but as it was pissing down on sunday i didn't go out.
Neil, is everything ok now?
Yeah the rest of the day was ok - i decided just to go out and not care about the fuel (although i did go a bit slower on the big left handers)
Rang Nathan - going around tommorrow
Just loved the straight :( sideways (just for fun) on to the straight then holding all the gears flat - cant beat that feeling
It was good to put a few more names to faces
They silver GTR that was there with me - he had an awesome time plus it was his birthday
i was having to much fun to do times!! sorry
couldnt do times anyway - as the others already know i had a fuel leak problem everytime i hit a left hander (most of the track :) ) which caused litres of fuel to escape, so i took it slow(er) around the lefts and looked forward to the rights :)
bummer! pity half the track is left handers lol. I'm guessing when your car was complied they didn't properly seal the fuel filler neck restrictor. oh well at least it's an easy fix. just need some devcon and 20 mins to do it.
Little unsure at this stage Baron, Greg thinks its nothing to worry about. It pumped some oil out a breather so I have to block it off. Seems the rotor doesn't like left handers either. Next run will be on his dyno to iron out some tuning issues.
Richard I did a lazy 1.56,,,and I mean lazy.
Oh and I shouldn't forget Duncan,,,,Thanks buddy you did a TOP job. Don't forget next time you have a problem with Navara to tell Nathan it could be the toilet. HA Ha.
Neil.
Neil.
not bad mate 1.56 just tootling around is certainly moving in the right direction. I am seriously hoping once you have spent some time in the car, and have it all working the way you want that you can knock JP off. although i don't know if i should be encouraging a ford to beat a nissan. man i am so conflicted.
don't worry about the oil though rotors are nonstop pumping out of everywhere anyway mate. it's normal that you need to fill up with oil and fuel at the same interval :P
oh and i wont ask what the story is with the navara/toilet isssue.
Baron, just to give you an idea of a lazy lap
1/ Turn 1, button off at the 200M mark no use of brakes
2/ Cruised into 2 but up it for the rent on the exit and still into it hard through 3 and 4 (my favorite section).
3/ Cruising again till 8 (another favorite) only because of the fun you have on the exit
4/ Cruising for the rest till the lead on.
I'm not out to knock John off the top,,,but It will happen at EC. His car is way way to heavy. Jason's car will be the one to beat. Don't be conflicted buddy you know deep down you love Rota's and the Capri's a fat looking car. Hey my wife even loves it.
Apart from the oil leak the car wouldn't pull it's EC diff, (4.94) it was just getting to 8 grand in 4th at the control tower and won't rev over 8. I'm thinking it needs some serious dyno time. Greg thinks the old Mallory tacho could also be a problem as it has a rev limiter.
Enough raving I'm out to the garage.
Neil.
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
    • RB20/25 covers don’t have threaded fasteners stock like RB26 covers. They are blind rivets so I will need to drill out and tap threads. I bought some M4x6mm button heads and will report back once done if I chose correctly length wise.    have also got some loctite
