Item: Alpine MRV-1507 amplifier
Item Condition: BRAND NEW
Price: $650
Contact Details: PH 0421582221
I have for sale a brand new ALPINE MRV-1507 Amp.
I live in Nowra on the south coast. Note. these amps retail for $730 US dollars
Amp has to go.
Ph: 0421582221
$650
This amp was bought to drive four 12" subs in a car i had. Crafted a custom fiberglass enclousure in the boot. Crashed the car before I fitted the amp.
I have since gorn away from car audio. The amp is brand new and has never been used. I use to work as a custom car audio installer and bought the amp after my boss won the SQ PRO class at summernats twice with one of these amps.
Read the specs and a review as attached below:
Alpine MRV-1507
With a stylized design and solid performance, Alpine’s latest class AB amp offers big power.
Alpine MRV-1507 Specs
Price & Contact: $730 USA; 310-326-8000
All measurements @ 14 volts unless otherwise specified.
Frequency Response (4 Ohm IHF Load 20Hz to 20 kHz, 1 kHz Ref.): +0 dB, -0.2 dB
L/R channel error, max deviation 20 Hz to 20 kHz: 0.2 dB
Phase Response (4-ohm IHF Load 20Hz to 20kHz 1kHz Ref.): +6.5 degrees, -12.3 degrees
Signal-to-Noise Ratio (Below Rated Output, “A” weighted): -118.2 dB
Distortion at Rated Output @ 1 kHz: 0.25% @ 900 watts
Output Power(resistive) minimum output 20 Hz to 20 kHz @ 1%THD+N (all channels driven into 4 ohms): 274 watts x 2 @ 14 volts; 225 watts x 2 @ 12.8 volts; 140 watts x 2 @ 10.5 volts
Output Power (resistive) minimum output 20 Hz to 20 kHz @ 1%THD+N (all channels driven into 2 ohms): 455 watts x 2 @ 14 volts 371 watts x 2 @ 12.8 volts; 227 watts x 2 @ 10.5 volts
Output Power (4-ohm IHF Reactive Load @ 60 Hz to 1% THD+N): 995 watts
Crosstalk (Referenced to Rated Output, 20 Hz to 20 kHz): -52 dB
Damping Factor @ 100 Hz, 2 ohms: 348
Voltage for Rated Output: 215mV to 4.5 volts
Idle Current Draw: 1.5 amps
Current Draw @ 1/3 Maximum Power: 63.5 amps @ 316 watts
Efficiency @ 1/3 Maximum Power: 36%
Power-Up Noise: -3.7 dB SPL
Power-Down Noise: 22 dB SPL
by Brian Smith
The MRV-1507 is a two-channel amplifier with power ratings of 225 watts x 2 or 900 watts x 1 into 1-ohm loads and 450 watts x 2 into 2-ohm loads. Features include an internal crossover and subsonic filter, line level outputs, fan-forced cooling, and a low frequency EQ with full parametric operation.
Performance
I’ll give it to you straight — You’d be hard pressed to find one that performs better overall than the MRV-1507. I’ve seen a whole lot of class A/B’s in this power range over the past few years and have come to dread them. They’re usually the biggest of pains to deal with and are often frighteningly unstable. Anything that draws 140 amps and hums like a high voltage transformer is bound to cause some apprehension. There are times when one feels led to probe the limits carefully, lest the magic smoke should appear.
By comparison, the MRV-1507 ran with no more fuss than a good amp half it’s size. Of course, it has a much larger appetite than a 100-watt x 2 unit, but it’s very well behaved and produces impressive performance specs. Signal-to-noise of 118 dB and 36 percent efficiency at 1/3 power are pretty rare numbers, especially in a kilowatt amp.
Connections & Adjustments
The MVR-1507’s chassis is laid out with power connections on one end and input/output connections and configuration switches at the other. All of the units variable controls are located on top of the heat sink with a protective cover. Connections to the amp include RCA inputs, RCA line level outputs, and 1/2-inch spade receptacles for all power and speaker connections. The amp has an extra B+ connection, which can be used to bypass the internal fuse and line choke. Switched adjustments include input mode, phase invert, crossover enable, and parametric EQ enable. Variable adjustments include input sensitivity, high pass cutoff frequency (30 Hz to 200 Hz), low pass cutoff frequency (30 Hz to 200Hz), and the parametric EQ controls, which include center frequency (30 Hz to 200 Hz), Q factor (1 to 10) and boost/cut (+/-12 dB), and a fixed subsonic filter.
Installation
A parametric bass EQ? Hello, now you’ve really got my attention. Simple bass boost is one of the most useless features in car audio. It wasn’t designed to fix problems; rather, the idea was to give the customer more of what they already had (bass). If you don’t know any better, or are primarily concerned with being obnoxiously loud, that might sound like a good idea. However, if you’re looking for SQ and do know better, then an arrangement such as the one found here will be much more likely to satisfy. The ability to cut rather than boost is particularly helpful. You can actually smooth a lump in response with a little bit of cut, but all the boost in the world will never correct a destructive resonance. Try removing what you don’t want rather than boosting what you do — it really works. (Alpine reports that this is part of the company’s BassEngine system concept — it allows users to maximize the sound quality and impact of bass reproduction in any vehicle.)
At about 2.4 x 10.3 x 21 inches, and about 19 pounds, the MRV-1507 definitely won’t fall into the small amp category. However, it appears to have a decent heat sink design in addition to fan-forced cooling. All controls are either recessed or otherwise protected and, well, it’s just a good looking amp. The subdued matte gray and brushed aluminum finish indicates that there are a few companies in mobile audio that have retained some measure of class. There’s more than enough room on the top of the MRV-1507 for one of those 1500-watt MAX POWER blurbs, but Alpine didn’t go that route. I guess tacky amps aren’t in their repertoire.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
