As the title states i am trying to work out where in the country is the best place to buy a RB26 from a 33GTR. Ultimately i would like to get the 33GTR half cut, minus panles and brakes so i can remove the engine myself (read:carefully) at my workshop.
I am not looking for the cheapest R32 engine i can find. Instead i am looking for a good quality R33 engine with around 100k kms or less on it.
Everyones input would be very much appreciated!
https://www.sau.com.au/forums/topic/87480-best-place-to-buy-a-quality-rb26/
i would say the easys place to find one would be japan but it takes abit of time, finding the engine then getting it on the boat and then waiting for it to come.
you could try
http://www.justjap.com
as they have halfcuts and engine for sale :)
you could try
I said in the country for a reason, its is not the easiest option for me to grow wings and fly to japan and find one and send it home.... for me anyway.
Anyone know anywhere else apart from just jap, really looking to hear from people who have actually purchased one and what there experiences were etc.
or u could just go to just jap!....
I wouldn't bother looking for a good engine, just buy any engine and rebuild it when you get it. A 100,000klm r33 engine wont be much better than your average 150,000klm r32 engine, especially if you start turning the boost up.
Build it up first and *know* that you have a good engine instead of taking a chance with a second hand one
I would reccomend Ultimate Performance Imports in Melbourne, speak to Dean.
I purchased a 33 GTR motor from Dean about 18 months ago, he told me they did a leak down on it and it was a very good, and that it was. When the motor arrived we took bearing caps off etc to check it and it was one of the cleanest motors internally my workshop had seeen. So much so it made 340 kw atw without a hitch and is still a very healthy engine. Would not hesisite to purchase another engine from them.
Edited by ido09s
thats EXACTLY the truth duncan and i have recently had to rebuild my "low km" rb26 which is f**ked a piston ring, so i would buy a cheap as shit motor and rebuild it to stock even, atleast u know its fresh :D
100 000km is alot for a rb26, my workshop said anything around and over that many km's and they dont last with more boost etc
good luck
Brad
seb has a r33 engine in the norther beaches only removed to be replaced by a tomie crate engine
pm me if you want his number
at least you can compression test it and give it a good look see
pete
What Pete says.
Im pretty sure Sebaz still has his engine for sale
What Pete says.
Thanks guys, exactly what i was looking for. Duncan hadnt considered that opttion thanks for pointing it out!
I have to rush out now, i will get back to this when i have time in the next few days.
Mick
You can do that but one day if you are called for a Full EPA you will not pass as the engine is older than the car. Guess thats the only downfall but hey, how often are you called for a full EPA? lol
    • Reasonably hard, although I haven't run it with the new Endless setup yet. The old brakes were F50's on 335mm rotors and the car did a 1:40.6 at Phillip Island which is a reasonable time, I'm seeing high 600s on the temperature paint. A guy I know ran the Endless fluid at WTAC without issues and he was doing 1:33's I think (Evo) with a 355/332 setup. I don't get out to the track as much as I'd like but we put the car on the hoist and spanner check every bolt and re-paint mark everything, bleed the brakes, change the fuel, check the coolant system and re-bleed blah blah blah before every event. Motorsport is expensive, RB's are expensive so a couple of hours before an event is time well spent. It's also a net time saving because if you can keep your RB from self destructing it saves you time in the long term!
    • Welcome Alice......hope you have a bit more luck from here on! What was done in the build?
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
