This Group Buy is currently closed.
There are no R32GTR Bilsteins left.
Bilsteins are attempting to get an airfreight shipment during the next 3 weeks.
However there will be only limited numbers in the shipment.
So place your orders now to avoid dissapointment.
:blink: cheers :)
  • Replies 239
Posted Images
It is possible if i can but the shocks now(if they get more stock), then later on down the track when i have more money i can buy the rest of the gear?
Yep, no problems, that can be done.
As an alternative, some guys have a left a deposit ($400) and Jamex puts their shocks aside until they pay for the rest.
:whistling: cheers :P
oh i will do that, do you know if there will be any more before the 5 months? my rear left shock is more like a pogo stick then anything.
after realising i read you post wrong, i will be depositing money for them.
Edited by GTR1993
  • 3 weeks later...
PM replied to.
Bilstein received a small airfreight shipment of R32GTR Bilsteins today.
This Group Buy is re-opened.
:wave: cheers :laugh:
Whats a recommended package to buy?
Would it be shocks, springs and stablisers? What about Polyulethane(sp?) or Nolethane(sp?) bushes, are they included with any of it?
cheers
cheers
I have included everything that I think is necessary in the list of parts.
I haven't included anything that I think is unnecessary.
The shocks have been selected so that their valving matches the spring and stabiliser bar rates.
The suggested alignment settings are included, to suit the parts used.
The bushes are necessary to achieve those recommendations (there are no standard adjusters, except small rear camber).
PM me for further details.
:yes: cheers :D
  • 3 weeks later...
Anyone got pics of the rear strut brace?
Yellow ends, with polished alloy rod, adjusting nuts at each end of the rod where it bolts to the ends.
:rofl: cheers :P
Good news and bad news.
The bad news is the small airfreight shipment of rear shocks that Bilstein received in July has sold out.
The good news is there are 20 (10 pairs) of rear R32GTR shocks arriving early September via seafreight.
The bad news is there is ZERO stock at Bilstein in Germany and no production is currently scheduled this side of Xmas.
The good news is there are an equal number of fronts in stock.
So, if you want a set I strongly suggest that you get in now.
:mellow: cheers :)
Edited by Sydneykid
QUOTE(williamsf1 @ 26 Oct 2005, 11:54 PM)
G'day Gary....
I see the R33GTR race setup, nice work!!! and great laps times!
will there be an R32 GTR race package also? and will it be any different without the shocks? i.e. is it the dampers and springs only that are different?
The stabilser bar rates are different, the camber and toe settings are, of course, different and the rear sub frame alignment settings are different also.
The R32GTR shocks and springs will be quite a while, they haven't even made a prototype yet.
cheers
PS; PM me if you like, I will let you know what the kit will be otherwise.
Have you gone any further with this kit. I was at Sandown saturday and the car was very unstable all around the track. Shocks must be on the way out. Has there been any progress with the race setup shock valving as I am in desperate need of some shocks and srings. (Modified my group buy whiteline springs to fit my teins).
I noticed in your track suspension setup replies to other people you recommend a 24mm front swaybar but supplied me a 22mm. Was there any reason for this. I only just realised.
G'day Gary....
cheers
Whiteline are currently changing their high end shock and spring supplier, so no news on a circuit kit from them.
In the interim I have tested quite a few different valving setups with the Bilsteins for circuit work. I used a coil over conversion kit with Eibach coil springs. They work very well with "R" type tyres or full slicks (different rates used of course).
If I remember rightly, the 22mm bar was supplied because you had Teins with rediculously high spring rates.
What rear bar do you have?
PM me for more details
:mad: cheers :laugh:
Hi SK,
The bushes and strut bar still havnet arrived. I sent you a couple of PMs but no response. Can you let me know when i should expect the kit to arrive? (order was placed on the 5th).
Cheers,
Kot (Adam)
Hi SK,
Cheers,
Kot (Adam)
PM resent.
:) cheers :)
PM resent.
Thanks SK,
The kit arrived today. Two questions tho;
- Do the rear upper arm suspension bushes require a press for removal/installation? (Or can i do it myself)
- Rougly how many hours work so you think it would taker a shop to fit all four bushes? (I might just get the aligner to do it)
Cheers.
Kot
Guest
    • Yeah, thumbsup from me. The distant shot of the bay just looks same-same as before.
    • Dad had a court case drag out with them from 1998 to 2004. He was in a not at fault accident, NRMA were the ones who covered the other person. They tried to blame his neck injuries on the fact he'd had an injury in 1981 on his extreme lower back where he slipped a single disc right near the bottom. Had been all cleared from that injury for years. This accident destroyed his shoulder, and f**ked a heap of discs in his neck, and he still has major problems with it to this day. Sarah's sister while on her L plates had a small Suzuki Alto, she had stopped to give way to an ambulance, and someone changed lanes behind her because there lane was also slowing, and rear ended her at 80km/h. (She had been stopped for a few seconds already too!). Car was completely f**kED. NRMA sent the vehicle around to 3 different workshops as they kept claiming "We believe it can be repaired, and not written off, we just need to find the correct workshop". It took 3 months, and a lot of arguing before they'd concede and wrote it and paid out. About two years later her sister had a Lancer, someone pulled out of a stop sign without stopping (in an 80 zone). Her sister swerved, hit the front of the other persons car (Instead of dead t-boning the drivers door), which ramped her Lancer, and made it roll multiple times down the road. It hit every panel on the way through. Her sister had slid her self out of the car, and remembers the ambos walking to the accident (They'd been sitting at a set of lights just down the road and witnessed it) and they were saying "Well, this ones going to be a fatality, no way you can walk away from that". Well, she did. And then NRMA sent two assessors out to look at the car, both of which wrote it off. They tried to send another assessor out, except a HUGE uproar was raised, and they FINALLY paid it out. That was on a car, that had damage to EVERY panel, you could see from 100m away the whole car was also twisted, roof bowed etc. Nah, we'll try get out of needing to payout on a $10,000 car... Her sister ended up with major shoulder reconstructive surgery being required, and was permanently limited in her ability to do her job as a nurse after that, as she can't (And was told before surgery too this would be guaranteed to happen) regain full strength in that shoulder. However, there was no choice to not have it, as she could barely use her arm, which was her dominant one, and was in near constant major pain. (And she's the type of person that would try and walk off a broken leg!) NRMA did the biggest run around on the personal injury side too for about 18 months, even to the point of trying to put 100% blame of the accident on Sarah's sister, even though the other driver admitted she didn't look, and didn't stop, and was charged by the police. Sarah used to have a Barina insured with them. It was a policy setup, paid all 12 months in advance. At the end of the 12 months, Sarah was living with me, I reviewed the renewal, it clearly stated "If you do nothing, your policy will cease on XYZ date". We did nothing, as we moved her insurance in with all of mine and I was with Shannons. We find out 10 months later, NRMA decided, because he DAD had a car insurance policy at the same address as what Sarah's mailing address was (Garaged address had been changed), that they'd put Sarah's (What should have been non existent policy) onto her Dad's month to month charges on his credit card. We had to jump through hoops, to get a refund. They didn't care that we actually found the letter that said "If you do nothing, your policy will cease" they made us prove we had NON COMPULSORY insurance else where before they'd issue the refund, and after they agreed to the refund, it still took another 6 weeks and 3 more phone calls for them to actually process it. They also had two insurance claims from storm damage, and they were an absolute cluster to get resolved as well (one vehicle, one house). Some how, up until about 3 years ago, her parents were still loyal to NRMA too, and we were like "How the hell are you so loyal to staying with them, when other places are so much cheaper, and they've f**ked you over every time you've ever had to make a claim?"
    • I got the four AN10 fitting welded up to the cam covers and started up making the head to sump breather/drain lines. The front passenger side cover I used a 45 up top and a 90 at the bottom into the stock VCT head drain spot (3/4" BPST to AN10 adapter) thats unused on the RB25DET NEO with some speedflow flame shield to protect it from the manifolds heat.   back passenger side was a 90 up top with some flame shield and 45 at the sump end. The rear drivers is 45 at both ends   the front drivers fitting is capped off for now but ready to go if i want to try moving the breathers around. I was told by the fabricator to leave all the welds raw for now to make sure there are no pin hole leaks. A lot of cleaning up, re bundling looms and degreasing to go as well as final assembly on the cam cover baffles. The first real test will be 28th March at a Circuit event. added complexity and more spots for leaks but overall looks relatively neat imo
    • Yeah i think the dash needs to come out. To get the loom or maybe just climate control and radio cluster. My mirrors are done i think the motors don’t work so well after flood haha i need the ac fan, you said you wanted to keep it for your 31 and interior loom not including boot. The wiper motor. I’m not sure how good the window surrounds are on the exterior on the pintara.  I will message you to get your bank details shortly
    • Just another barrier put up to stop cars being modified. When we're all driving Chinese sewing machines, you won't want to modify it anyway, and you'll likely already have slashed your wrists and be locked up in a padded room for your own protection.
