Sk,
duno if you got my pm. I'm interested in getting everything besides the sway bars at this stage, please work out a price and send me payment instructions.
Cheers,
Dave
Dave has bought the last set of R32GTR front Bilsteins, if you have an R32GTR and are desparate I can arrange an alternative. There is extra cost (around $100) as they would have to be revalved to suite. There are still some sets of rears in stock at Bilstein. Consequenlty I will hold the Group Buy open as long as I can.
:thumbsup: cheers :)
  • Replies 239
Posted Images
Hi there sydneykid.. sorry to msg u here.. your pm box is full.. just checking whether you received my pm about springs/shocks for my r34 gt-4
cheers
PM sent
:D cheers :P
Hi there SK,
I have a few knocks from the front and back of my 32 GTR and can see a few worn bushes around.
Question is that if I replace:
Front and rear Camber Bush's
Caster Bush's
Cradle Bush's
Would this cover all the suspension related bush's or are there others?
Also I believe that the front camber kit is reduced to $183?
Thanks for your help!
Hi there SK,
Caster Bush's
Cradle Bush's
PM sent
:laugh: cheers :P
Good news, after much searching I have been able to find 10 sets of R32GTR front Bilsteins and they arrived today.
Update, 2 sets have already sold, so don't delay.
:pirate: cheers :kiss:
Thanks SK
Finally got my kit installed, I went with a stiffer spring and some adjustable rear upper arms that were'nt in the kit, but essentially the full GB. You get used to driving on the street with saggy suspension but when you get it on the track it really focuses you on the problem. The handling is now sharp and predictable, this street package plus my extras delievers as advertised... good scope for adjustment for MC days etc yet compliant enough for the street. The ride height advice was spot on too. Money well spent, also thanks to W.A. Suspensions for the excellent advice and install
SK,
I'm a definite... Put me down for the full monty please.
Just got to find a pair of standard rear upper control arms (Anyone???) or a pair of adjustable rear track bars to compliment the adjustable rear upper control arms I already have... anyone know where to source these?
Regards,
Shuey R32
SK,
If I wanted a slightly harder spring for the rear end of my R what would be the least painful way of getting it done & would the shocks need revalving? All the reast of the suspension kit is from the parts list on this thread.
hi sk i would like to order 4 bilsteins and 2 sets of bump stops for r32gtr i have worked out the cost to be $1195 is this correct?. if available can you pm me so i can transfer money , thanks loren.
SK,
Whiltein only make the one rear spring rate, you would have to go to a coil over kit.
Revalving depends an how much higher spring rate you want to use.
We should take this to a PM, rather than clog up a Group Buy thread.
PM sent.
:thumbsup: cheers :laugh:
Sorry, this Group Buy is closed for shocks as there is no more stock of rear R32GTR Bilsteins. I will re-open it for shocks when the next shipment is confirmed.
The other items (springs, bushes and stabilsier bars) are still available however.
:( Merry Xmas to all at SAU :)
PM sent.
:( cheers :ninja:
OK, but your in box is full and/or disabled...
Gary, I have finally got enough money to get the rest of the stuff i need. If i was to order bushes/stabilizer bars now when could i expect them to be delivered with all the christmas stuff going on? Thanks
Bushes are usually in stock at Whiteline
Stabiliser bars take 4-5 working days to make as Whiteline do not keep stock
Delivery is via Toll priority and usually takes 1-2 working days to anywhere in Australia.
So, no chance before Xmas, closed between Xmas and New Year. My guess would be 5th January, but that's just a guess.
:P cheers ;)
Guest
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
