Indicators Blinking real fast!
Well i had to pull my front 400r bumper off to fit my new cooler and in the process 2 of the bulbs in the indicators on the bumper broke, so i replaced em with new bulbs. We had to remove the fan for the AC also cause it was in the way of the cooler. Now my indicators blink real fast like there is a bulb not working, but they all work fine. Could it be caused by the plug for the AC fan being left off cause it was removed and its detecting this as a fault!
Here a pic of the front bar and cooler for those that havent seen it yet!
Oh and i got 183kw@wheels at 0.9 bar boost after the s-afc was retuned with the new cooler
https://www.sau.com.au/forums/topic/8753-indicators-blinking-real-fast/
Sure you replaced them with the correct wattage bulbs. I think the rapid blinking is caused by the system detecting the wrong voltage drop, which will vary according the the wattage of the globe. I can't see how the A/C fan would affect the indicator voltages. Otherwise you'd get different blink rates when the fan was on and when it was off.
i am preety sure i replaced em with the correct bulbs. How many different wattages do they come inm they r the 1'c with the 3 lipped end. Does the left and right indicators run off the same circuit so if 1 of the left bulbs r not working the blinker will still bink fast even when u indicate right?
heres my dyno graph 2!!
The increase in blinker speed is caused by a bad/faulty/short circuit
Same thing happens if you forget to connect your driving lights back up when you take the front bar off.
Sounds like your bulbs are incorrect
Originally posted by INASNT
no not yet, but i changed my headlight fluid and it didnt help either!!! :D
yeah? well give it a go dude...
It's probably the blinker fluids..and don't try and use the headlight fluid for the blinks, it will stuff things up...
Good luck with it :D
I did the same thing and they blinked too fast, either get the correct wattage bulb or place a resistor from Dick-Smith in series with the bulb, this will give it the correct volt drop and they should blink normal.
See'ya:burnout:
when i was working with cars and puting them back together and doing panel beating this was common... mainly cause one of the lights (as they run in series) isnt working.
when one stops working or blows then it puts the series out and starts to flash faster but generally only on the side which the bulb is affected.
Inark,
Normaly that is the case, that one of the lights has blown, but if you put in the wrong wattage globe then that has the same effect. Need to increase the resistance of the line back to what the original system was by adding a resistor.
See'ya:burnout:
can any 1 give me the correct wattage for em. And remember its the 1'c on the front bumper. Thanks
Here is !! :P:D
Copied straight from my Skyline manual.
Head Lamp 12v 55w
Fog Lamp 12v 35w
Side Lights 12v 5w
License Plate 12v 5w
System/Rear Lights 12v 21/5w ???
Reverse Lights
Sedan 12v 18w
Coupe 12v 21w
Indicator Front 12v 21w
Rear 12v 5w
Cornering Lamp 12v 21w
So front bar indicators should be 21 watties.
J
Originally posted by Jay95R33
Here is !!  :P  :D
Head Lamp              12v  55w
Fog Lamp                 12v 35w
Side Lights               12v 5w
Reverse Lights
        Sedan        12v 18w
        Coupe        12v 21w
              Rear     12v 5w
J
thanks jay!
Originally posted by GTS-t VSPEC
Jay,
You have a Skyline manual, how did you score that?
See'ya:burnout:
:P :P
It's just the owners manual... Not the workshop manual :P
I'd looooove to get hold of a workshop manual.
My last cars I'd always get a Gregory's manual so I could work on the car myself. With the Skyline I'm a bit nude, but willing to get in there and give it a go.
J
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
    • I just try to entirely stay away from ladder now unless it's something basic maintained by electricians. Even then and to your point, it mostly ends up being blocks I wrote in structured text.  PLC's are slowly going towards C, C++ and C#. I just wish Allen-Bradley would jump on the bandwagon.
