Just Bought New Car And Need A Cheap/free Deck :)
  • Replies 50
I know I had to put a new fuel pump on both of the ones we have, the stock one sits just next to the tank, ditch it off and get one from coventries or something, but new fuel pump is defenetly the way to go.. Also a common problem with them is they have trouble starting when it's really hot.. like 32c +
Its already got an aftermarket electric fuel pump fitted, i dunno if thats the problem...
It runs great when it starts, but has to try very hard to get up to speed as i drive from Warnbro to Freo each day in it (100kms a day) and its only a 4sp man, so its revving its box out going 80 :D
Yeh man it is cool, but i have a problem when I try and start it sometimes. If i put fresh petrol in it from nearly empty, it doesnt start. If i park it on a hill, it doesnt start. I figured out if i leave it for about 2 hours it will start up fine. Im guessing that theres water in the fuel tank and it gets sucked in when it gets swished around the tank. Also its bad on fuel at the moment.
Any ideas?
sounds like the float in the carby isn't shutting properly... this will cause extra fuel to leak into the engine when its running and has fuel pressure, or when the fuel level in the tank is higher than the carb (ie full tank or parked on a hill). You can check it by taking the air filter off and having a look down the carby when you in a situation where it normally won't start... if you can see fuel running out this is the problem. also the oil will be thin and smell very petroly.
normally this is caused by crap being sucked up from the fuel tank. normally you can just pull the carby apart and clean it and all will be good, or go crazy and buy a carby kit. make sure you install an inline fuel filter if it doesn't already have one.
I should be picking up my bunky this week, 3cyl Charade :D
Will be good to have a car that runs on almost zero fuel, takes parking dents and that I can generally not care about. Having a nice car as a daily driver adds alot of wear & tear, just not worth it IMO
Carry's are great :D think of all that space you can put gearboxes etc in the back :D kinda scary to drive though :)
    • me too wasnt real happy and cost me a penny or 2 to replace
    • But there's the archetype for the name plate! Here's my view on that stupid TÜV ruleset. Buy a brand name aftermarket piece of equipment. In this case, the Mines front pipe we're talking about. Get it TÜV certified on the car. Damage the underside of it, say on a speed bump. Cut out the damaged section, replace with fresh metal. (For the sake of the argument only), continue doing that to the whole pipe until it is all gone, replaced with new metal. Is this grandfather's axe still the same front pipe? The design hasn't changed (much). The pipe walls are in the same places. The flanges are in the same places. It is functionally identical. How does this differ from a pipe that is ever so slightly different in fabrication (ie the number of welds in it, a few mm here and there in terms of where the pipes run, are joined, etc)? Anyone with 0.5% of a brain can see that there is absolutely no way that the performance (power, environmental aspects, noise, etc etc) of it can be any different than the genuine Mines pipe. Maybe even Mines made 2 versions of this design, with the same differences. How would anyone (say a TÜV inspector) ever be able to differentiate between them? And yet, they are so bloody anally retentive about this stuff. Mad. How upset would they be if you had the wrong spring washers on the flanges?
    • Sakura (cherry blossom) tree at the end of a path going through Kabutoyama Park in Nishinomiya, Japan. Taken with Sharp Aquos R8
    • After a fairly extensive search using Japanese terms and checking Minkara etc, I couldn't find anything even close to your front pipe in the photos. I'm no expert but the two pipes merge really close to the flange connected to the catalytic converter which is rather unique from what I've seen, which makes me think it's more than likely a custom front pipe. The welds and 'more pipe sections than usual for a brand name pipe' makes it seem like a custom one.  Here's some photos of an old Mine's front pipe. You can see that it's just 4 pipe sections as opposed to 6, and arguably looks more like a 'production' front pipe:
    • Wtb r33 low side s2 ac line
