  • Replies 101
Out of curiousity what was your terminal speed with the 13.2?
Originally posted by 400HP
I had two passes which were pretty ordinary. 13.2 ET with 2.1 60FT (I know I know....)........I don't think I'll have any more mods in the car by then so I hope to run a 12 in current trim.
As long as I line up VISHES I'll be happy BWHAHA =)
Originally posted by RONIN
ed: myself, carlo, and nick will be there to spectate. I believe Minh is coming out too. not sure if he's running though
ok...you guys know what I look like hahaha...
I'll be there with my tripod and camera...hope to get a few vids...
With a better launch, you could have possibly cracked the 12s.
I mean barely..I'm talking 12.9
You should be getting closer to 1.7-1.8 on the 0-60ft time. Work on your launches. ie. It's a GTR. You want to light up the rear wheels so the front wheels actually do some work. So, rev to rev-limiter if not close to it. Release clutch (quickly, hell sidestep if you want :(:) ).
Make sure to brace neck accordingly. The snap into 2nd could also do some damage (to your neck or car...what ever is weaker)
:D
poyz - I think 107mph or something like that?
Hello Peepz...the impression i had from this drag meet was that SAU would hijack the scene from the rotaries and V8s....but that was not the case :) oh well next time we can turn up in numbers :)
As for my result, I ran a best time of 13.4 @ 103mph @ 1 Bar with 2.0sec 60ft time :)
u ran a 13.4 linus?
damn.....i wanna run mine but im afraid ill run a 16+sec+!!!
i guess ill have to suck it up and give it a go.. :)
Atlantis Aquariums :) heard u were there on sunday, thats my mates shop ;)
I was supporsed to turn up but i was too buggered from carts, ....she was not happi i didn't come :)
Silvias RULE :bahaha:
Originally posted by DON91E
u ran a 13.4 linus?
Atlantis Aquariums ;) heard u were there on sunday, thats my mates shop ;)
yeah i was happy with that run....all night i was doing low 14s..then last run i decided to launch a little harder :)
yep..i was there with my friend...she wanted some seahorses!!!
i thought it was intrusive since they were having a private grand opening party...
    • Hello everyone, I am from Malta and have recently bought myself a fully stock 1992 Nissan Skyline GTS. It has the RB20DE engine and thus is NA. Unfortunately, not a lot of information can be found online related to the GTS, unlike the information for GTS-T and GTR variants. Apart of the Skyline, I also got a 1984 Porsche 924 2.0l NA and a 2002 Renault Clio 1.5DCi for everyday use. Excited to be apart of the community and perhaps get better information on cars such as the GTS.
    • The fuel pump bracket just slides straight up.  Below is a pic I stole off a site. But basically put hand in for fuel pump, wiggle it all about a bit while pulling up.
    • Went digging Duncan, there's another "item" that sits down under the plenum that the second pipe from the IACV goes down to. I believe that's the one that is apart of the cold start portion, and it then comes back up under the middle of the factory top plenum. I believe you will find it is unneeded on the forward facing plenum on Cheryl.   I just went digging further for some pics on the location of the one way check valve, and found something that confirms my thoughts from the first half of this point. I feel you can just block off that port that is coming down.     I can also confirm, the other line that you were thinking for vacuum that will just need a one way valve put into Cheryl is 100% correct too. The one way valve is normally screwed into the back of the factory inlet plenum.
    • You’re an absolute legend man. Cheers.
    • The rule of thumb for any GTR thats doing a single turbo conversion is..... seqy... and when i say seqy, i dont mean the pos PPG either. *flamesuit on*
