won't be able to put the car on the dyno as it will be off the road as of the 7th of october ready to put the new motor in but i will bring my beasty 1975 ke30 corolla down and watch and meet you guys and put some names to faces!
  • Replies 294
Nothing wrong with the VL's. :)
The VL' should be on par to that of the rb25det running the same mods, if not a little better due to the 25's crap ecu that does its rich and retard.
Come along Nath, pass through and we will head down together.
Edited by Cubes
I've seen REALLY low cars get up there no probs
Shaun backs them onto the footpath first, then up the driveway. It seems to work well
Short of getting a set of ramps to put on the driveway, what else could you do?
Ok, ill put mine in....im sure it'll be going by then.
Itll only be around 220rwkw...hell bring on the shootout mode, ill be up around 239rwkw :P
Shauns driveway is no probs. If you cant get your car up it (or Shaun) then its too damn low to start with ricers....
tried to get jaffa along, but he'll be at work :D
If a couple of people come on the day without registering interest here, is that a problem? If so, i'll find out from them for sure and post names.
Edited by GFXman
hey gtrGhosTDoGG11,
When can i get my steering wheel back? saw it yesterday closeup and its absolute sh!thouse, even your seats got a tear but a deals a deal. I had to also get a new fuel reg for $180. My car will be ready for sure unless i damage something dyno tuning next wk but hopefully ill be cracking 300rwkw :D Oh btw i also will need to put in some iridiums b4 dyno, same job isnt it?
Edited by popeye132
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
    • I dunno what the "best" one is....but when my 040 died late last year, after about 20 years of screaming service....I put in a 255. Like any such thing, you have to finagle it a little bit - it's not a no-brain swap. But it's not hard.
