I believe u made 218rwkw. :O
I need a dyno run printout to be able to dial in all the numbers so the graph looks right as no doubt you have picked up mid range as well.
Sky30,
Bl4ck32 was running 1bar, I was running stock rb20det actuator, i.e no boost control, boost would spike up to 12psi at ~2000rpm then tail off to 9psi by 4000rpm where it would go on to make peak power.
60km/h is approx 2200rpm. Its strange as if that is the case then 160km/h is only ~5900rpm. <scratches head>
I am going to need every ones tyre sizes to apply a correction.
Not to forget the diff ratio correction for both Natho's and the R33's slightly higher 4.11:1.
As I said prior, if your keen to compare off boost ignition maps i'm keen to do so. Depending how much works gone in to your maps you may pick a little off boost torque up. :D
Edited by Cubes
  • Replies 294
Running 235/40/18's would act as if you had an ever so slightly higher diff ratio, so your top speed vs rpm will be higher than the others, as a result also your down low power will be down.
A good example of this is Natho's VLT, that runs a 3.45:1 diff ratio and the dyno stopped at 5100rpm yet his wheel speed is up there.
I think its wrong to compare bl4ck32 and my dyno's on the chart I posted prior. Something is just wrong with the speed vs rpm, possibly shaun fiddled with the wheel speed calibration. Don't know. :O
Edited by Cubes
Joel, can you add mine to that graph too, just for comparison sake, or post the xls file and I'll do it myself!
Also, I presume you're doing the calcs for the diff ratios to do a torque comparison at some stage. Should be interesting to say the least.
I also think the wheel speed on these dyno graphs aren't correct (I think Shaun mentioned that), as redline on my car in 3rd gear should be nearer to 200km/h than the 176 the run stopped at.
EDIT: Also, are those graphs all from the same day, or are there others there?
Edited by chops
The only dyno runs that were not done on the day were Bl4ck32's and mine.
I mainly put them in there for a comparison to Sky30's, how much of a difference the small stocker turbo's make to a 3ltr running a GT35R .82.
The wheel speed is always incorrect.. But what I do think has been modified since Bl4ck32 and I ran on the dyno is the wheel speed/roller calibration.
As I know 100% at 2000rpm mine was making 100rwkw.
Can you post up or pm me the first dyno run? I'm keen to see how the power curve looks. I had mine ran in v8 mode on D&T's dyno, the power curve resembled the lump style power curve of your second run.
Edited by Cubes
No time at the moment for wheel speed calcs.
Shouldn't be too far off as its only a 3.9:1 ratio, unlike Natho's 3.45:1, his run finished at 5100rpm.
Definitely looks strange how the run starts at 100km/h. What RPM was your run started at?
But it should be all road/roller speed related, every one drop their car in 4th and accelerate away.
Edited by Cubes
No idea what rpm it was started at.
That's a bit of a problem with autos though, if you give it full throttle at any lower speed it would drop back a gear, which is why I guess it starts so high up in rpm. Tuners with the software have the luxury of being able to lock the trans in 3rd gear.
First run was done in a different V8 mode though, not Shoot_6, so I don't think it will give the comparison you're after. I only have the hard copy, if you really want it I'll scan it and drop it to you.
If you want to do wheel speed things at a later date, redline on mine should be 6200 rpm, so you can work back from there. (approx 35.2 rpm per indicated kph, which would suggest approx 3500rpm starting point)
Hey dudes, we should get all our turbo's highflowed at once and get a cheap price because we are doing 3-4.
something i definately want to do, but unfortionately cant afford at the moment :)
The RB30 is nice but it also requires a nice manifold and decent sized turbo to prevent the top end nosing over.
It is nice though... I'm able to accelerate off the lights from idle and have it accelerate as hard from idle as a stockish (exhaust) LS1 Manual. Unsure if the edited ones have any more balls off idle or not.
So its definitely got some torque.
Wheelspin is a big issue for me at the moment, I put it down to worn subframe bushes causing axle tramp and a half stuffed diff that doesn't completely lock up, probably also causing part of the axle tramp.
God help it once its nudging 280. :D
Sky30's definitely sounds awesome on the dyno, I wouldn't mind grabbing either an audio file or small vid clip off some one at some time. :rolleyes:
Edited by Cubes
    • Can perhaps see how the R33 appreciators would think so.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
