Yes that would be the ideal way, it would be a hell of a lot easier on mybehalf too!
From last experience ie dinner cruise, we had lots of interested people but only one person rocked up. The only reason why iam doing the deposits is to make sure we dont waste Shauns time, as he could of booked other things on the day.
I thought this would be a good idea to get genuine interested people and reward them.
THose are my thoughts.
  • Replies 294
Agreed :)
My car is off the road thanks to some 4WD owner who cant reverse, crashing into it with the rear bulbar. Ripped my brand new cooler and bumper (put on 2 days earlier) off and pushed radiator and fan back into engine. If my car is back on the road by this time i will still attend otherwise i will have to give it a miss!. f**king P plate 4wd drivers!!
Someone deposited
10/10/2005 DEPOSIT 9999 5115
Who is this? You didnt put any name!
Yep thats mine, bank lady didnt know how to put my name in the transaction and the other teller told her to enter 9999 then she would be able to put a name next to the transaction, i guess it didnt work, but thats my payment from monday.
Updated first post.
Also, this is the order so far. Just let me know on the day if you dont like where you are and maybe I can change it.
SAU PEEPS COMING
NAME-----------------PAIDYET?
1. lang Yes
2. MS-75 Yes
3. Jagged Edge Yes
4. Chris32 Yes
5. GFXman Yes
6. syx Yes IN FULL
7. gtrGhosTDOGG11 Yes
8. sky30 SOON IN POST
9. ?
Edited by gtrGhosTDoGG11
I noticed that 10 people haven't deposited yet so I just did so then. Should show up tomorrow hopefully.
Even though my clutch slips, its only sometimes in 4th so if I drive it there easy and dont heat the clutch up, and get the dyno done in 3rd, hopefully it'll be OK. Haven't had it run with the cooler on yet so it'll be good to see how it goes even if the clutch does slip during the run.
Its already installed.
I'm running a dedicated feed from the battery via relay.
Under load its only seeing 11.something volts.
Not the 13.8 as it should. :)
Then later on I will ditch it and throw an 044 in there, I'm currently running a 910 that won't cut it for over 250rwkw. :)
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
