  • Replies 294
  chops said:
Duc, it's SATURDAY, not Sunday.
thanks for correcting me Will, my head is all over the place atm. ;) Ill put that down somewhere so I dont rock up on the right day.
  SLYWINE said:
too late to enter?
is this only for skylines?
i want to put my cima on a roller dyno as hub type don't give mine a full reading.
Since we have an LS1 VY Calais, i think a VG30 Cima is acceptable ;)
  Nozila said:
savalas - is your 33 the white one with bonnet pins and a gt wing? i see this vehicle when i was driving past the other day. looks good from a quick glance.
yes thats the one, made 306kw's last thursday on 1.4bar and running just premium. Think I might wind it up this time.
im assuming the engine has been built for big hp as i doubt standard internals can cope with that....
on another note, bit off topic but do you have any coilovers for r33's in stock atm. all i see on your site are one's for silvias/32's.
  gtrGhosTDoGG11 said:
Start time is around 10am, finish time is whenever we run out of cars.
Should be before 3:30, 4pm.
6 hrs ish total time on dyno? damn!!!
might need to bring some food along....... :lol:
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
