Hi guys
I've just installed an RB25 turbo on my RB20 retaining the RB20 actuator. Now since there wasn't provision on the RB25 turbo to connect the actuator to, I drilled a hole in the intercooler pipe between the intercooler and the intake manifold. Works well but i am only getting 0.6bar or about 9psi. At first I thought it had something to do with the hose I used as the original hose that was connected was a combination of 3 hoses joined together. Two with a larger internal diameter and one thinner. So since i didn't need the length i just used one of the larger diam hoses. This morning i joined up the other two pieces which included the smaller diam hose and now i'm only getting 0.5 bar.
Now as i understood it, using the RB20 actuator on the RB25 turbo should give me a base pressure of 10psi, up from 7psi or so. On the stock turbo I was already getting 0.5 to 0.6 bar. So 8 or 9psi. Which sounded right as I have a turbo back 3 inch exhaust. So i thought with this setup i'd be getting around 11-12psi or 0.8 - 0.9 bar.
Any thoughts on this? My only idea is that the stock intercooler is posing a restriction as it is stock and i believe quite oily as well, judging by the amount of oil present in the intercooler pipes.
Edited by replicate
quick guess your not using the standard actuator to compressor hose?(this is my pet excuss for everything now)
You should try and keep it if you can.
My 2530 ran .7 bar through the stock cooler just like my standard turbo did.
I've always had a bit of a boost drop issue.
I've put it down to the crappy designed aftermarket dump pipe that v's up 10mm or so in front of the turbine wheel, the 'performance specialists' didn't stretch the pipe over the flange correctly.
I've seen another dump done like this since by another mob.
Edited by Cubes
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
    • When you say basic rebuild, you mean an oem rebuild?
