For sale: One set of very pretty, second hand HKS Hiper-D suspension with adjustable coil covers. Came with 1990 GTR R32 imported from Japan. Also one six point roll cage, black padding, nicely fitted. Was difficult to see with black interior in car.
Located in Lower South East South Australia.
Reason for sale: had to put standard suspension in due to registration, and roll cages are illegal in South Australia.
Asking price of $2200 including freight for the suspension. Feel free to negotiate price. Any reasonable offer on the roll cage will be concidered!
Payment options are open (ie through direct deposite etc) and will be discussed with buyer upon purchase.
Please PM any questions, or email [email protected]. Feel free to call either 0417 213 036, or (08) 8737 3787. If you leave a message I will get back to you.
Edited by Poledra
Sorry, was at work and had to do the ad in a bit of a rush. They came with the car from Japan, which is a 1990 GTR R32. From the information we receieved about the car before importing it, the suspension hadn't been on there long. So they are second hand. Was a bit naughty and took her for a quick night time drive when we first got her with that suspension in it... so thats the only time its been used in Oz.
Price can be argued if you like... I have just bought some standard suspension from Brisbane and it cost $100 in frieght.
And as a girl, I think they're very pretty... :D
If your interested I can give you a ring if you like...
Thanks muchly
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
