Hey guys,
I know this should be in events but at the moment its not an event, yet. I am doing some driver training on the 12th and 19th of october and this is just to see if anyone else is interested cause the more lines the better and if there is a few we might have some leverage to get a deal to get some $ off. i am doing the luff driver training courses at oran park. the day of the 12th is the stage 1 course and the 19th is the stage 3 course with cams observe so that i can get my cams licence. the cost of the 2 days is $630. You have to have completed stage one to do stage 2 or 3. If anyone wants more info go to http://www.ianluff.com.au/index.php?option...id=23&Itemid=63
I know people have a lot of different opinions on who to go to for driver training and which course is better but i have had many friends go through this course and all agree youll learn alot and have loads of fun while doing it...
Any takers??????
https://www.sau.com.au/forums/topic/87598-anyone-keen-for-driver-training/
  • Replies 44
Top idea, this is great training and its a shame so many people talk so much but don't go along to something like this.
I guess from your post you are already booked in, SAU is running a CAMS training day thru Aaron McGill on 22 November which would be another idea. I've done CAMs courses with both Luff and Findlay (but not McGill personally) and I would say that the Findlay one is the one to try if you really want to be challenged and learn :)
Unfortunately i'll be away for the Level 1 otherwise I would definately come. I've done the finlay one - however really want to do a level 2/3 advanced course.
Any recommendations? I'm pretty sure finlay's don't do an "advanced" one.. only the cams and normal..
Want to do it before it heats up as well..
Yeah duncan already booked with some firends but might be keen for the november one as well, if my car is in one piece.
Hey mate,
there is plenty of other level one days between now and the 19th, Im just booked into the 12th because that was convenient for me, try and get a friend to do one of the earlier ones with you then we can all hook up for the stage 3.
sanger - I may see you on the 19th for the stage three course if I can't get in for next wednesday's one
Brush that one come to the one on the 19th...... you know you want to. :)
hey yeh id be interested.. perants are paying atleast half :D  hopfuly ill be there too
yeah same. my old man was going to get me golf lessons so i suggested that this might be a smarter option and he agreed. you dont hear of many people getting killed by someone slicing a golf ball so i think the driving lessons are a better bet.
Hi All,
As a licenced trainer and assessor, I can give you the good oil !
Peter Finlay's driver training days are the better of all of the packages going at this time.
He may be a cranky style of a bloke at times , but he can teach you more in one day than all of the others.
Good Luck with it.
MIB
Hey guys,
Any takers??????
yeh i hopfuly should be there for the 2 days now.. perants will pay so its all good.. just seeing on if its booked out or not.. so yeh.
wasnt booked out when i checked late last week.
hope to see you there
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
