  • Replies 44
wasnt booked out when i checked late last week.
hope to see you there
nice.. just wondering if ya new.. ya know how they use witches hats (cones) as like boarders that ya gota go around or sumthing, im not too keen on sliding into one of them with my front bar.. its proberly crack my car or sumthing... do ya know what the go is?
Not sure mate but it wouldnt surprise me if they did. Although you would have to be very unlucky to crack your bar...... let me refrase that, im sure damage to cars would be pretty uncomon as otherwise they would use something even more flexible and soft than witches hats..
I am keen if I can score some time off work.
Nice, if they tell you there arent any spots left get back to me as the mate i was doing it with is pulling out. so there will be one more spot but i am ringing up about that today so be quick if your keen....
:P
on this topic I've done Aaron Macgil day and he was great. also did a day with Daryl Cullen (who also does the Peter Finlay days) and he was excellent too. Both guys taught me a lot about my driving, and particularly about Oran Park GP track too.
i did this day a few weeks ago, had an absolute ball...and i think for my first time out on the track they taught me well without bombarding me with information.
for the inexperianced driver this day suited me well!
Well did the level 1 course on wednesday. Was loads of fun and would recomend it for everyone. while only being basic stuff i still learnt heaps! I think everyone should be made to do the level 1 course (or something similar) before they are allowed to get there p plates.
Now looking forward to the level 3 course next week.... might go do the level 2 course as well.
good stuff, what did they cover? proper braking and turning lines? knowing what you are doing can make a hge difference to how you use the brakes :D
Yeah basically the just coverd emergency stopping. Talked to you about how to get the best from your brakes depending on the type, eg abs and non abs. Also wet the skid pan down and showed you how your stopping distances changed and also how to swerve around simulated problems ahead while staying in control etc.... Also talked alot about every day saftey stuff like your driving position, Stuff that i thought i knew all about but i still learnt alot
Looking forward to the level 3 when we hit the track so they can find me a bit of extra speed and some better technique. I was going to do some more performance mods to my car but decided it would be better to learn how to use what i have to its full potential first!!!!
The Findlay course is on often.
I'm happy to organise a group of SAUers if there is more interest in doing the course?
Yeah sounds good although i will have to save some money first, might also do the level 2 luff course first just to have the full set and then look into the finlay one. The level 2 luff course is the slid control part of their courses to so it looks like alot of fun, the gave us a demo of some of the stuff in the level 2 course at the end of the level 1 day... Was a big tease.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
